Rear door rubber seal coming off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BradC, Jul 21, 2019.
  1. BradC
    BradC Member
    42
    25
    The rubber seal for my rear driver's side door is coming off, as shown in the pic below. It's not cracked or ripped anywhere. It often comes off enough that the door doesn't close all the way, and I need to push the rubber back on.
    What's the best way to address this? I thought about using some epoxy to hold it in place, but I figure that would create a mess if I ever need to replace it.
    Thanks.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Super glue
  3. NewHybridOwner
    NewHybridOwner Active Member
    607
    279
    W. Michigan
    I think super glue would be too brittle. Better to use a flexible adhesive. Can't think of a name right now, but one of the auto parts stores should have something.
  4. Mendel Leisk
    38,245
    I'm thinking pull it off more, then "redistribute" it somewhat when pushing it back on. Pull it down and push firmly into the lower corner, and the inverse at the top corner.
    CR94, Ed Beaty and BradC like this.
  5. Mendel Leisk
    38,245
    I think they do use some tacky black stuff in places, though I could be thinking of other cars, past Hondas. If they did there's likely enough in there to still be viable, you wouldn't need to add more.
    But to me that just looks poorly installed, like a ripple in the carpet that can be remedied with a bit of stretching and compression in other zones. Maybe the car was recently detailed or painted? Or someone getting out of the back seat snagged on it, pulled it partially off.
  6. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    Do not (NOT) use Super Glue. Perhaps a bit (just a bit, judiciously applied) of RTV.
    I also like Mendel's idea of 'pulling off/redistributing'. Might not have to use any adhesive with that approach.
  7. BradC
    BradC Member
    42
    25
    It wasn't recently detailed or painted. It's possible one of my kids snagged on it when getting out of the car.
    I'm thinking maybe I'll try to use a little RTV to stick it back on. Thanks.
  8. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    It's easy to push back in place.
  9. BradC
    BradC Member
    42
    25
    I've tried that - it doesn't work.
