Rear brake noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ryan Washburn, Jul 23, 2019.
  1. Ryan Washburn
    Ryan Washburn New Member
    Concord, Nh
    2010 with 198k. Replaced rear pads and calipers. Right side has odd rubbing sound. Not grinding or squealing. Could this be caused by uneven caliper movement? Looks to me like the caliper isn’t moving evenly when braking and the leading edge (topside) moves first. Slide pins are lubed and moving freely. Tried to upload vid but can’t for some reason.
    52,187
    welcome!
    did you orient them properly, according to the service manual?
    #2 bisco, Jul 23, 2019
  3. schmuber
    schmuber Member
    115
    84
    Georgia
    Raise the side in question and spin the wheel by hand. You'll hear and see the source right away.
    PS: Had a bad experience with Bosch QuietCast "springless" pads. Went back to the regular pads with springs… problem solved.
  4. Mendel Leisk
    41,746
    Yeah when reassembling it's mandatory that the cross pattern on piston face be oriented like an X, so that the pin on back of pad is in between the spokes. Further, you want to ensure everything is well seated thus: pump brake pedal multiple times, then reconnect 12 volt, then a short test drive.
    On return, apply and release the emergency brake a few times, chock front wheels, raise rear, and check that the wheels will easily spin a couple of revs with a good push.
  5. ChapmanF
    18,398
    What had happened to the calipers, that they needed replacement?
  6. schmuber
    schmuber Member
    115
    84
    Georgia
    Damn rodents are getting out of hand.
  7. Mendel Leisk
    41,746
    Very good point. I wonder if he meant to say rotors??
