Just a thought... Recharging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by horent135, Aug 2, 2019.
  1. horent135
    horent135 Junior Member
    44
    CA
    2014 Prius Plug-in
    Since our PIP can be recharged by plug/gas. Why can't gas recharge the whole battery? instead of just ~1.5ish miles. There must be a way to unlock so the motor can recharge the whole battery ~14 miles. Any thoughts?
    52,405
    yes, they added that feature to the new prime.
    other than saying anything can be done, i can only say that no one here is brilliant enough to do it.
    we're still trying to figure out basic repairs on the cars, not hack the software (and maybe hardware)
    that would lead to an inefficient use of gasoline
    noonm and N.J.PRIUS like this.
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Seems to me I recall at least one other poster saying he fully recharged his PIP while driving for quite a while on rolling terrain. I suppose it's possible.
  4. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    Yup, it’s called stacking. The trick is to get the ICE warmed up and to leave enough EV so you can recharge the battery by switching between EV and HV modes repeatedly. Switch to HV when accelerating, going uphill and cruising at high speeds, and then when decelerating or going downhill, switch to EV. I’ve stacked the battery to full on a fairly long trip that way even though I had only 1.3 miles of EV left when I had the PiP in the past.
    It’s a little easier on the Prime because it’s quite a bit more efficient, but I don’t take the Prime on really long trips.
    iPad ? Pro
  5. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Doesn't Power mode do this. Albeit slowly.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Forcing the gas engine to fully recharge the battery regardless of conditions would be inefficient and self-defeating.
    And the PIP still used much of the "regular" hybrid programming, I think.
  7. fuzzy1
    10,603
    For normal, typical driving use (outside of certain special conditions), this defeats the entire purpose of making a plug-in car.
  8. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Stacking works really well. That's why I call it a car with a built-in game. I generally end up with at least 58 mpg on long trips with hills.
    jerrymildred likes this.
  9. Tideland Prius
    16,623
    I'm guessing stacking is more efficient than force charge since you're just driving to the terrain and simply just moving the EV/HV threshold that's artificially set by the computer.
    (If we agree on the term "stacking", I can add it to the PC Glossary)
    jerrymildred and Pluggo like this.
  10. bisco
    52,405
    by adding miles to ev, you're taking away from hv. like force charge, it would be an interesting study in lost efficiency
  11. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    I’d agree with that statement. Not quite as efficient as pulse and glide, but much easier to use for drivers. Better than pulse and glide with hilly terrain and when trying to keep up with traffic.
    iPad ? Pro
  12. drash
    drash Senior Member
    2,590
    1,334
    Upstate NY
    XLE AWD-e
    Actually when going down a long hill with a state trooper sitting at the bottom, putting it in EV and using B to keep my car from going the 85 I hit on the previous hill (with my wife yelling at me), efficiency was the last thing on my mind. ;)
    On the previous hill I was trying to convince my wife I was using kinetic energy to help me back up the hill. She wasn’t buying it.
    Stacking also helps with peace of mind.
    iPad ? Pro
    Pluggo, jerrymildred, noonm and 4 others like this.
  13. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Hybrid battery charge mode is documented on page 91 of the Prime manual. It does reduce HV efficiency in bringing the battery up to 80% charge. So the primary use would probably be while in HV mode on the highway to build EV charge for when getting off the highway.
    Raytheeagle likes this.
  14. Tideland Prius
    16,623
    ^ and also having enough charge in the battery for remote climate.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I used stacking now and then in the PiP. But only in certain situations where I was on highways with stop lights (no hills anywhere around here) and then planning to do some surface street driving.
  16. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Put it in D, put your left foot on the brake and floor it.
    Will it charge the battery? Yes
    Is it a complete waste of fuel? Yes :)
