Buying a used 2011 Prius?
Discussion in 'Gen 3 Prius Main Forum' started by Alygator, Aug 10, 2019.
  1. Alygator
    Alygator New Member
    Omaha
    I am looking to buy a used 2011 Prius Five loaded (with tech package it was hard to find) 85k miles, all the service has been done at toyota (I checked on my toyota website). so I'm asking if I should buy the Carmax Warranty? has anyone else experienced problems with their prius and used Maxcare warranty for hybrid cars?
    I have done my hours of searching and reading this forum about EGR issues and Oil consumption problems. but I'm pretty mechanically inclined so I can clean the EGR, EGR cooler, intake manifold. install an Oil catch can etc.
  2. bettergolf
    bettergolf Active Member
    493
    369
    Sanford NC
    If you can do that kind of stuff yourself, I say skip the Maxcare. Not that much happens to these cars anyway especially if you do the egr, occ, etc,
  3. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Without list price of car, maxcare & what it covered disclosed in the post then there's not enough info to reply with an legit answer.
    Bought mine from carmax also. Just know that carmax car's are typically listed a few thousand dollar higher than kelly blue book values.
  4. Alygator
    Alygator New Member
    Omaha
    The price of the car is 13,998, Maxcare is what I was really wondering about.
    Has anyone bought it for their prius and used it? does it cover the battery electric motors?
    since you bought your Prius at Carmax did you purchase Maxcare? if not....knowing what you know now about the car would you have bought it?
  5. 2014
    2014 Member
    30
    31
    MA
    General wisdom for those who are mechanically inclined is not buy the maxcare (or other used car warranties), do most maintenance and repairs yourself, and save the maxcare warranty $$ and use it to fund future repairs (if any) that you cannot do yourself.
  6. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    The extended warranty won't cover the hybrid battery. That's probably the expensive part needing to be replaced after the car hits its 10th birthday.
  7. Mendel Leisk
    41,818
    The brake booster's pretty expensive too, and there's been a fair number of failures. There's warranty extension program for that, definitely check with dealership and the net.
  8. Alygator
    Alygator New Member
    Omaha
    Thank you guys for all your input, I'm going to skip the Maxcare and just put that money away for a repair fund.
