Just joined the RPF1 club!
Discussion in 'Gen 4 Prius Accessories and Modifications' started by denny nguyen, Aug 11, 2019.
  1. denny nguyen
    denny nguyen Junior Member
    houston, tx
    2015 Prius v wagon
    Just swapped my OZ's for a set of RPF1's and wanted to show off a bit ;-) 18x8 +35
    TheRedRocker and krmcg like this.
  2. krmcg
    2,592
    2,390
    Whittier, CA
    Really Nice!
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Nice! How do they compare weight wise though?
  4. Mattheww
    Mattheww Junior Member
    25
    Kansas
    Two Eco
    That's a perfect look for a Prius imo. Has it affected your mileage at all?
  5. denny nguyen
    houston, tx
    2015 Prius v wagon
    i had the same size OZ Allegrita's with michelin MXM4's. The overall weight is 1lb less than the OZ's (OZ's with worn tires were 40.2lbs vs 39lbs RPF1 with NEW continental PCLS)
  6. denny nguyen
    houston, tx
    2015 Prius v wagon
    im seeing about 1-2mpg decrease for the same commute. Not sure if its the new tire, or new offset of the wheels. Went from +45 to +35.
    previous tires were michelin mxm4. new tires are continental pure contact LS. same size
  7. TheRedRocker
    TheRedRocker Member
    47
    46
    Kansas City, MO
    Looks great, Denny.
    Where did you get your wheels?
