2003 Prius won’t start
Discussion in 'Generation 1 Prius Discussion' started by dlfoster, Aug 14, 2019.
  1. dlfoster
    dlfoster Junior Member
    Georgia
    2001 Prius
    Hello everyone. Hopefully someone out there can offer some help/advice for the problem that’s occurring with my friends 2003 Prius. Recently somehow he started the car and drove it a little ways, not that far, with just hv battery power, and then his car died on him and will not start up. I did run the Toyota techstream software on his car and noticed that his SOC % for the hv battery was at 0% so that may be the problem. With a fully charged 12v battery when you try to start the car the ready light will flash three times and you hear several clicks from the hv battery but nothing else happens. There was one code that came up and it was p3000-389 but it doesn’t stay so maybe it’s the ecu under the passenger floorboard. I’m running out of ideas at this point so whatever input you have is appreciated.
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    If his HV battery is at 0%, it won't start. And probably the battery is no longer among the living. They don't like being completely depleted. And charging without a grid charger is problematic. I understand the individual modules can be charged, but it's a lot of work and probably won't save the battery. Would be nice if you could borrow a grid charger and a pigtail. Time for a replacement battery--which may not be economically feasible.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Sounds like a great place to start............On another note, it's pretty hard (but not impossible) for a HV Battery to really be at zero soc. Check the voltage and see where it's at. Keep in mind normal is 280-290ish for a Gen 1. If it's around 265 or less, it's either severely depleted or has some significant individual module problems.
    mroberds likes this.
  4. dlfoster
    Georgia
    2001 Prius
    Yeah I found it odd for the reading to say 0% but I don’t think it was inaccurate. I think it’s just severely depleted so I’ll have to figure out a way to recharge it if possible.
  5. Q*bertZ
    Q*bertZ Member
    155
    39
    greenville south Carolina
    2002 Prius
    Put a 3/4inch (same as 19mm) boxed end wrench on the engine crankshaft pulley bolt and try to turn over the engine manually. If it wont turn over it could be that the transmission fluid has never been changed and the planetary gear inside his transmission is locked up. We got a car with 170,000 miles and this is what happened to it. Because the HV battery could not turn over the engine it gave and error code that said the HV relay was bad. This was not true since that HV battery was working in one of my other six Priuses. We took off the transmission pan and there was so much crud (technical term for fine graphite looking metal shavings) they covered the pick up tub screen. We checked the pick up tubes o-ring and it was fine. We separated the engine and transmission to verify the engine would manually turn before going to the junk yard and getting a transmission. Installed junkyard transmission and the '01 prius is getting 50 mpg.
    WHCSC likes this.
