Where is the flasher relay?
Discussion in 'Prius v Accessories and Modifications' started by Vishnu, Oct 11, 2014.
  1. ozjimjam
    ozjimjam Junior Member
    35
    17
    22
    australia
    2016 Prius v wagon
    Thanks for the information, I bought a spare prius v speedometer from the US, i will get my father in law to do the modification on the spare one first , just in case things go wrong.
    can you post some pictures here ? thanks
  2. rjparker
    7,612
    4,466
    Two (or tow) alternatives: 1. Add a trailer tow harness and use that circuit to run the leds or 2: (my favorite) keep an extra bulb in the back cubby in case one of the car bulbs ever fails and save big (especially considering I have never had a turn signal light go out in eight years).
  3. ozjimjam
    35
    17
    22
    australia
    2016 Prius v wagon
    Here are more info, found on a car forum in China, that the car (not a toyota) happened to be also using the BTS5240 flasher chip.
    He connected some wires from the chip to his custom made LED bulbs, and fine tuned the number of resistor needed before hyper flash stops AND keeping the faulty light bulb detection function at the same time
    the owner replaced its resistors. Depending on what wattage LED bulb to be used, adding adequate resistors base on calculation.
  4. ozjimjam
    35
    17
    22
    australia
    2016 Prius v wagon
  5. plusaf
    plusaf plusaf
    324
    Raleigh, NC
    As of this posting date, I get an Error 404 (and in Japanese, yet!)... any alternative links?
    and yes, my dealer's 'electrical guy' said pretty much the same thing about there not being a separate, replaceable flasher...
    It's the current draw that is being sensed, and I'm wondering whether or not a small electronic module could fool the flasher circuit into believing that the LEDs are really incandescent...
  6. plusaf
    plusaf plusaf
    324
    Raleigh, NC
    I bought mine on eBay and the seller is willing to let me return it and refund the nearly $19 for it.
  7. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    Yes, I believe they're called resistors. ;)
    Air_Boss likes this.
  8. ozjimjam
    35
    17
    22
    australia
    2016 Prius v wagon
    Hey, check my thread, we did it few my month back, you need to solder 2 resistors near the flash chip, better use adjustable ones
    See here https://priuschat.com/index.php?threads/209226/
  9. whitrzac
    whitrzac New Member
    25
    madison
    Just did this on my 2014 V. Using slavania LEDs
    I needed to use a 22k resistors to get rid of the hyper blink
    ozjimjam likes this.
  10. whitrzac
    whitrzac New Member
    25
    madison
    I used some small through hole resistors as I didn't have any smd ones on hand. After this was taken I applied some silicone to hold them in place long term.
  11. whitrzac
    whitrzac New Member
    25
    madison
    22k worked well with the 1.7w white LEDs.
    It hyperflashed with the 1.5w amber LEDs.
    Replaced with a 33k and its working fine.
  12. ozjimjam
    35
    17
    22
    australia
    2016 Prius v wagon
    Great Job !
