Plug-in Prius Battery Upgrade
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Ben@Boston, Jul 3, 2014.
  1. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Inferring something without any quote or even context. Ugh. You know quite well the Chinese supply will be for the Chinese market. You also know "small" is so vague, it only serves to confuse. Reality is, there will be multiple sources for cells and a few more stacks is still well under "larger" sizes.
    Consider that 60'ish km target for this market. Isn't that the ideal balance of cost/capacity for very high-volume potential ?
    #141 john1701a, Aug 16, 2019
    48,986
    the only way to hit 60 would be a more efficient battery, or a redesigned prius. either (or both) are possible, but cost will be the driving force
  3. john1701a
    12,749
    5,243
    57
    Next-Gen is defined as being a redesign.
  4. bisco
    48,986
    what was this gen defined as?
  5. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    "This Gen" Prime is current
    "This Gen" your PiP is obsolete. :rolleyes::oops:
  6. bisco
    48,986
    so this gen 'prime' was not a redesign?
  7. Prodigyplace
    11,696
    11,317
    Central Virginia
    Not a major redesign from Gen 4
  8. bisco
    48,986
    so, 'next-gen' will be a major redesign from gen5?
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  10. Prodigyplace
    11,696
    11,317
    Central Virginia
  11. bisco
    48,986
    its contagious :eek:
    mrlebop and Prodigyplace like this.
  12. Prodigyplace
    11,696
    11,317
    Central Virginia
    Keep it up North;)
  13. bisco
    48,986
    i'll keep the windows rolled up as i cruise down 95 next january :p
    Prodigyplace likes this.
