Debadging the Prime
Discussion in 'Prime Accessories and Modifications' started by mhye01, Aug 4, 2017.
  1. mhye01
    mhye01 Member
    57
    Woodland Hills
    Hi guys, quick question before I give this a try tomorrow. Does anyone know if the badges on the prime, hatch and sides, are simply double side taped on or is there a hole in the panel like the older generations? I personally don't like how the badges take away from the car and want to get rid of them.
    #1 mhye01, Aug 4, 2017
    maximumdose likes this.
  2. MNdriver
    MNdriver Senior Member
    549
    577
    I agree. Hate them!
  3. mhye01
    mhye01 Member
    57
    Woodland Hills
    yuppp...so any idea? lol
  4. Mark57
    2,945
    2,738
    OK
    Can you find the badges on-line as a replacement to see if they show the back side or mounting method in the details?
  5. MNdriver
    549
    577
    A black Sharpie?
  6. mhye01
    mhye01 Member
    57
    Woodland Hills
    Great suggestion...I shall take a look.
  7. mhye01
    mhye01 Member
    57
    Woodland Hills
    LOL...if it is more than just double sided tape i think i'm going to just use some plasti dip n make it black.
  8. Elektroingenieur
    2,515
    3,278
    Three Touring
    Be aware that the name plates are functional, not just decorative: according to Toyota’s Emergency Response Guide (PDF), they help to identify the vehicle as a hybrid for firefighters and tow operators, who may need to be aware of the hazards from high voltage and battery electrolyte.
    That said, the Repair Manual (available by subscription to techinfo.toyota.com) mentions pins—and by implication, holes in the body panel—only for the Back Door Ornament Sub-Assembly, the Toyota logo in the center of the rear hatch.
    I can’t say for sure that there are no holes behind the Side Panel Emblems (“PLUG-IN HYBRID”) or No. 2 Back Door Name Plate (“PRIUS PRIME”), but the removal procedure just says to use piano wire to cut the double-sided tape, after applying protective tape to the surrounding area, and the installation locations are specified by distances from other parts, not by reference to holes.
    Clark_Kent and Mendel Leisk like this.
  9. Brian G
    Brian G New Member
    Orange County, CA
    What's up, man? Did you ever debadge your Prime? If so, were there any holes in the car behind the badges? I appreciate any information you may have. Thanks!
  10. Bombtrack
    Bombtrack Junior Member
    Chicago, IL
    I would like before and after pictures. I may consider removing the badge as well.
    Plus, more people will ask what kind of car it is :D
  11. teamHoffman
    teamHoffman Junior Member
    York, PA
    Any Update or Pictures of this? I want to get rid of them also.
  12. jungleland1972
    73
    65
    Chesapeake Beach, MD
    It's strange, my dealership put stickers on as their badge. Each letter of the dealership name was an individual sticker. I got the stickers off fine but there is a strange ghosting around the stickers that I can't seem to get off (I used WD-40 and the turtle wax sticker remover). The spots where the stickers were looks great but if you look at it in the right light you can still read it because the area around the stickers have a bit of ghosting. I can't figure out what it is.
  13. Salamander_King
    Salamander_King Senior Member
    11,009
    8,938
    New England
    I had the same type of indivisual 3D lettering type logo of the dealer on my previous Gen3 Prius. After removing all logo, I did have some ghost image of where letters once were. I didn't care so mach about the looks. I just did not want the dealer name on my car, so I lived with it. On my new Prime it was thin paper type sticker and it came right off without leaving any residue.
    #13 Salamander_King, Sep 13, 2017
  14. jungleland1972
    73
    65
    Yeah, you really have to look at it in the right light to notice it. I just find it odd that the surface that had the letters on top of it is clean but the area around it is off a bit. Makes me wonder what they used to put the stickers on.
    Salamander_King likes this.
  15. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Try using some Goo Gone. that stuff is amazing!
  16. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I removed the rear oval on the back and replaced with one of my choosing.
    The scratch marks on the side were from the string that was used for the removal.
    They were easily fixed with touch-up paint from the dealer (which had to be ordered).
    I didn't know that there were pins back there, and I didn't know how thin the paint was.
    Here is the view just after removal.
    priuscatprimeguy likes this.
  17. kevins007
    kevins007 Active Member
    116
    116
    Milwaukee
    Try using a clay bar in that area
  18. slothsandwich
    slothsandwich Junior Member
    27
    Denver
    2018 Prius Prime
    Anyone have before and after pics yet - want to see the Prime with and without badging to know if it's worth the effort. Also interested if any pins are in the side and tail badges or are they all "Stickers"
  19. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Check my car for debadge
    slothsandwich likes this.
  20. maximumdose
    maximumdose Junior Member
    honolulu
    2018 Prius Prime
    I debadged my Prime, both side and rear badges. Love the result. I used hot water, pliers, and goo gone.
