Getting Flipped Off Is A Badge of Honor
Discussion in 'Gen 3 Prius Main Forum' started by PriusMPGenius, Jun 12, 2019.
  1. PriusMPGenius
    PriusMPGenius Junior Member
    85
    82
    Kingston
    Amen. Couldn't agree more.
    Data Daedalus and Montgomery like this.
  2. Mendel Leisk
    38,253
    It would take a draconian crack-down to rein in the scofflaws. Around here pretty much nobody:
    1. Signals (properly, consistantly).
    2. Comes to a full stop at stop signs and when turning right at a red traffic light.
    3. Stays under the speed limit (Yeah I know, even contemplating that invokes consternation, reservations).
    4. Follows at a safe distance.
    Data Daedalus, John321 and Montgomery like this.
  3. ETC(SS)
    6,495
    Why, I wonder?
    Because educated people display more empathy?
    I know how you feel....only I'd probably concentrate more on social activities.
    Lots of different kind of mentors out there.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Lack of education is an assumption on your part. For all you know, the guy might have two PhDs.
  5. PriusMPGenius
    85
    82
    Kingston
    I work with a lot of highly educated people with Ivy league degrees, this type of behavior is beneath them.
    Data Daedalus and Grit like this.
  6. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    One in Tailgateology & the other is in Jerkism.
    Data Daedalus and RMB like this.
  7. Mendel Leisk
    38,253
    Still, I wouldn't conflate college degrees and demeanor.
    Data Daedalus and fuzzy1 like this.
  8. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    There's the solution - everybody gets an Ivy League degree and all bad behavior is eliminated. Simple.
    VFerdman and Grit like this.
  9. PriusMPGenius
    85
    82
    Kingston
    :ROFLMAO:
    You are on fire today.
  10. PriusMPGenius
    85
    82
    Kingston
    Classic straw man argument. You can't win the debate using those!
    Grit likes this.
  11. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    I'm not debating anything. Just commenting on the obvious correlation.
    Edit - on second thought, this might not be that simple. Ted Kaczynski (the Unabomber) had a degree from Harvard and advanced degrees from Michigan and was on the Cal Berkeley Faculty. So education may not be a reliable method to improve behavior.
    #171 jb in NE, Aug 21, 2019
    Data Daedalus likes this.
  12. PriusMPGenius
    85
    82
    Kingston
    I guess I just value etiquette and courtesy. I hold doors open for people, I share the road, if I have my cart of groceries and I see someone behind me with just one item I let them go ahead...stuff like that matters.
    Data Daedalus and Mendel Leisk like this.
  13. PriusMPGenius
    85
    82
    Kingston
    I thought it was a logical fallacy.
  14. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    I think the others on this forum do as well. I can only control me, and if others are not courteous and exhibit good etiquette, I can either get upset or just ignore/avoid them. I choose the latter. In the case of an annoying tailgater on a two lane road, once they are past me the problem is resolved.
    I also try to give people the benefit of the doubt. Everybody has a bad day, hour or minute every once in a while. As an example in this case, the other driver could have accidently run over his dog in the driveway just before he encountered you. You never know.
  15. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    He’s an outlier of sample size.
  16. Fastfret7
    Fastfret7 Junior Member
    24
    Virginia
    2015 Prius c
    Happens to me all the time on the good ole HWY 95!
  17. PriusMPGenius
    85
    82
    Kingston
    He took too much LSD and isolated himself from people.
  18. PriusMPGenius
    85
    82
    Kingston
    I agree, but usually the stuff I post on here is contemptible behavior from deplorables. These aren't people just slipping up, these are people that present their selves on the road as aggressors and endanger people around them. A guy wants to roast tires in some parking lot have at it. You want to ride my bumper and then roast the tires when I let you pass well imo that makes that person a mook and I just chuckle at these people.
  19. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    You're doing more than just chuckling. They are under your skin.
  20. PriusMPGenius
    85
    82
    Kingston
    Maybe briefly when it happens but for the most part I use the experiences as inspiration to create content on this site in hopes of meeting like minded people that encounter mooks and chuckle. So far I haven't found that to be the case.
