2006 152,000 miles shakes violently until 5 mph
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cyle dale, Aug 23, 2019.
  1. Cyle dale
    Cyle dale New Member
    Eugene, Oregon
    Just bought this a few days ago and everything was fine until I stopped at a stop sign... when I pulled away, it shook violently, didn’t want to accelerate, and shook harder and faster until it reached 5 mph when the engine kicked in, then everything seemed fine... but it now does this every time I get below 5mph... there were no lights for a Little while, but when I was almost home, the dashboard lit up... triangle with ! And check engine light. I have it at a shop to run the codes... they haven’t told me the codes yet, but said it is transmission failure. This doesn’t sound like the transmission failures that I’ve read about on here, and seems to be fine after I get over 5mph... don’t want to replace the transmission and find that it doesn’t fix the problem... also, is it a job I could do, or is it more complex with the hybrid system?
  2. oldtechaa
    oldtechaa Active Member
    336
    223
    NZ
    2013 Prius Alpha
    Since the transmission holds essentially the only moving parts that would be affected by the engine starting, it does sound likely that it would be the transmission. Others might have opinions for you too.
  3. Mendel Leisk
    40,550
    Is it a dealership with Techstream diagnostic software? Either way, I'd get the codes, look them up and post here before proceeding.
    Skibob likes this.
  4. Kenny94945
    Kenny94945 Active Member
    842
    418
    Sausalito
    2016 Prius v wagon
    This is only a guess.
    Maybe not Hybrid relevant.
    Fuel injectors...at idle the flow is being limited for some reason.
    Once pressure builds, at 5 mph, the injectors begin flowing enough fuel to smooth the engine.
    Just a guess.
    Again not sure if your symptoms occur when only operating only on battery, eg before the gas engine engages.
    Good luck.
  5. Cyle dale
    Eugene, Oregon
    It is only in battery... before the gas motor kicks in!
  6. Cyle dale
    Eugene, Oregon
    They said they would give me the codes on Monday... it is a mechanic that claims to be a Prius specialist.
  7. Patrick Wong
    18,200
    6,492
    Sounds like the transaxle needs to be replaced.
    If you are able to replace the transmission in other vehicles you should be able to replace a Prius transaxle. There are several posts about how to do that in this forum and you can obtain factory repair manual info at techinfo.toyota.com
    Cyle dale likes this.
  8. Cyle dale
    Eugene, Oregon
    The more I read up on the Prius, the moreit sounds like the transaxle. thanks, I’ll let you know how the repair goes!
  9. Cyle dale
    Eugene, Oregon
    Got the Codes...
    P0A90
    P087A
    P0A7A
    C1241 (I think this is from all of the shaking)
    C1300 (I think this is from all of the shaking)
  10. Patrick Wong
    18,200
    6,492
    P0A90: If you could get the three digit info code that comes with this, that would help to narrow down the problem area. Otherwise the problem could be the transaxle, the motor, hybrid vehicle ECU, or inverter.
    P087A: I do not think this is a valid Prius DTC
    P0A7A: This points to a problem with the inverter or with the wiring harness that connects the inverter to the hybrid vehicle ECU
    C1241: The skid control ECU is complaining of low voltage on the 12V bus
    C1300: malfunctioning skid control ECU
  11. Cyle dale
    Eugene, Oregon
    I’ll work on getting the three digits, but what are the chances that it could just be a problem in the wiring harness(P0A7A) that causes an underpowered MG2(p0A90)? That would also be the easiest fix of all of the options right?
  12. Patrick Wong
    18,200
    6,492
    You can get the factory repair manual at techinfo.toyota.com which is a subscription website. When you look up the P0A7A DTC, the manual will show you which wires to verify between the inverter and the hybrid vehicle ECU.
    Certainly that repair is easier than replacing the transaxle, inverter, etc. The chances depend upon whether there was accident damage to the wiring harness, or perhaps a rodent infestation which caused the wires to get chewed up.
  13. Cyle dale
    Eugene, Oregon
    Replaced the transaxle over the last two days... took about 16 hours and went very smooth! It was my first major job, before this, the most I had done is axle/ suspension/ starting system work... it was a tough job, but well worth it... total of about $350 as opposed to $2,200 quotes by private mechanics!
    Skibob likes this.
  14. sugar land dave
    137
    houston
    Nice! Congratulations on your hard work and dedication to the DIY nature of the forum! (8>)
