Dealership video; 2020 Toyota Prius Prime Line Up
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Aug 25, 2019.
  1. Mendel Leisk
    41,791
    I don't think fog lights are considered to be headlights? This page:
    Headlight Use Laws for All 50 States | YourMechanic Advice
    says:
    South Carolina
    Headlights
    • Headlights must be in use from 30 minutes after sunset until 30 minutes before sunrise.
    • Headlights must also be turned on whenever windshield wipers are in use.
    • Headlights should be turned on when you cannot see at least 500 feet in front of you.
  2. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I think you would be wrong, given the specifications for headlights, I think they fit, and they count as low beams in the total count of forward facing lights if they are not yellow, but whatever, I've never been stopped, nor have I seen anyone else stopped when running like that.
  3. Tideland Prius
    16,589
    In North America. For whatever reason, the rule says the headlights must be on if fog lights are on. Makes no sense.
    In Europe, you run fogs (front and rear) with just the parking lights so you don’t have the water vapour reflected back at you.
    drash, Data Daedalus and Mendel Leisk like this.
  4. Trollbait
    12,647
    I remember it not always being so.
    Improperly aimed, too bright aftermarket installs probably ruined it for the rest of us.
    Tideland Prius likes this.
  5. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,691
    Somewhere in Wisconsin
    2013 Chevy Volt
    Around here when you encounter oncoming traffic legally any light other than low beams is to be off,
    Sadly it seems to be popular to fit your high seated transport device with 100,000 watt “spot” lights in the fog position, aim them toward the trees and leave them on 24/7
    Prius Maximus likes this.
  6. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    My 2016 Ram can run fog lights without the headlights on. I rarely use them, only if it's actually foggy. I get blinded by the "fog"/"driving" lights in conjunction with headlights, and don't want to blind oncoming drivers. These days, even headlights only is too blinding with many vehicles. Especially when topping a hill.
  7. Trollbait
    12,647
    I turned them on in the rain to counter the aspect of the abyss that asphalt can take on at night.
    Since I couldn't turn them on without the headlights, i couldn't say if they would help in the fog. The last car I drove in which that was possible was a '90s era Grand Prix, and its fog lights were actually yellow.
