Hybrid Assistant or Torque support. Just got my 2020 Prime XLE. Traded in my Gen 3.
Discussion in 'Prime Main Forum (2017-2022)' started by yiujai86, Aug 28, 2019.
  1. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    Hi all. Got my Supersonic Red yesterday and I'm I'm asking this while sipping free electricty from a free charge point near work.
    Is there anything similar to Hybrid Assistant or Torque ObD? I had a lot of PiDs on torque and also enjoyed adjusting the HV fan speed on Hybrid assistant on the gen 3.
    I'm very conscious about battery temperature because my gen 3 hv battery temperature would hit 120 farenheit in the sun with aggressive driving and the only way to keep it under 105 was to use Hybrid assistant to set the fan to max.
  2. Salamander_King
    Salamander_King Senior Member
    11,023
    8,958
    New England
    Both Hybrid Assistant and Torque app work on my 2017 PRIME. Though I have not played with Torque app that much.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Can you not continue using Hybrid Assistant? It works on the Prime, as noted above.
  4. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
  5. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Under the Hybrid Assistant settings, there is a section for fan control. You can specify a max or min battery temperature for fan control.
    I suspect you won't need this on a Prime. Mine has been out in the hot sun, run on EV in hot temperatures, and the car is good at controlling the battery temperature without additional parameter adjustment. As you can see from the photo below, I have this Hybrid Assistant feature disabled.
  6. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    Ok I'll try messing with the settings. If not I'll be content with only knowing the temperature
  7. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I find that the recording and playback feature of Hybrid Assistant is very useful. Drive you car in hot weather and then use Hybrid Reporter to export the data.
  8. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    The Torque PIDs to disable reverse beep for Gen3 work for Gen4, too.
    Id been trying to find the one that allows fob to roll down windows, but gave in and bought an eBay mini VCI / TechStream for $20.
  9. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    Either the Hybrid Assistant is broken or the OBDII is broken or the 2020 Prime has different parts.
  10. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Hybrid Assistant will display very limited data if the ODB-II reader isn't compatible.
    SFO likes this.
  11. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    Just got Carista OBD and Hybrid assistant still doesnt show the temperature. I did download Dr Prius though and it shows the battery @100F all day while im driving and it being almost 95F degrees outside. At night the battery is around 92 to 94F degrees while driving and or charging.
  12. Salamander_King
    11,023
    8,958
    New England
    Maybe Carista is not fully compatible for HA. Hybrid assistant recommend ODBLink LX adapter and states "Full functionality of Hybrid Assistant is possible only by using the ODBLink LX adapter (OBDLink® LX Bluetooth | OBDLink® | OBD Solutions)."
    See this page. Hybrid Assistant: OBD
    I have OBDLink LX adapter, and seems to work flawlessly with HA, although from time to time it has difficulty initializing the adapter at the start.
    #12 Salamander_King, Sep 10, 2019
    yiujai86 likes this.
  13. Salamander_King
    11,023
    8,958
    New England
    From HA page linked above: Hybrid Assistant: OBD
    OBDLink LX
    Reading speed: fast
    Fully tested, the Hybrid Assistant Team strongly suggests using this adapter if you want full functionality
    VS.
    Carista
    Reading speed: medium (2x slower compared to OBDLink LX)
    This adapter is fine for HSD2 and HSD3 cars, but it can't handle HSD4 cars (i.e: Prius 4, C-HR, Corolla)
    #13 Salamander_King, Sep 10, 2019
  14. patcoghm
    patcoghm Junior Member
    57
    Can you tell me where is this PID to disable the reverse beep. I can't find it
