Weight of Wheel/Rims vs. MPG
Discussion in 'Prius c Fuel Economy' started by 88Keys444, Aug 31, 2019.
  1. 88Keys444
    88Keys444 Junior Member
    37
    36
    illinois
    Hey guys,
    I still have the stock OEM wheels on my Prius C, which I believe are about 16.5 lbs. I found some wheels weighing at 11.1 lbs, so I'd be getting about 5.5 lbs removed in unsprung weight.
    Has anyone experienced any change in MPG after getting lighter wheels? I'd love to increase MPG and I love the look of them, as well.
    Here's what they look like:
  2. PriusCamper
    PriusCamper Senior Member
    13,025
    5,293
    Pacific Northwest, USA
    Yes it will make a big difference, one of the few things you can do to improve MPG... The reason this is not done often is because getting 4-5 pounds of weight out of each wheel means you're going to spend several thousand per wheel for forged alloy racing wheels, which makes for a bad day if you hit a curb, especially if you're a frugal Prius driver. :)
    But maybe you're the lucky winner who got a great deal that makes all the rest of us jealous... :)
    Or maybe your stock wheels were those lame super heavy cheap steel wheels they were putting on early model Prius C and you're just upgrading to normal non-cheap wheels and it will make a difference, but not as much?
    My dream has always been able to win the lottery and blow $10K on some under 10 pound pound racing wheels... The few people who have done this back when Gen2 Prius were first coming said it will made a noticeable difference in both acceleration and MPG. Anyone who's worked on bicycles will tell you... The lighter the wheel, the better you'll be in a race.
  3. PriusCamper
    13,025
    5,293
    PS: If the lighter wheels don't match up to exact spec for max mpg and you aren't using LRR tires, the MPG won't change much and in some cases could get much worse.
    will the engineer likes this.
  4. Mendel Leisk
    41,879
    Funny thing, steel rims of comparative size are pretty much neck-and-neck for weight.
    PriusCamper likes this.
  5. bisco
    52,368
    interestingly, the difference in mpg of the hycao le vs the two higher end packages is supposedly in the wheel size and weight.
    affects drive quality too, i suppose
  6. Mendel Leisk
    41,879
    Our 3rd gen's 17" rims are around 24 pounds apiece, oink...
    Merkey likes this.
  7. 88Keys444
    37
    36
    illinois
    Second one:) I have a 2013. The ones I found are on Amazon for 105 a tire. Nothing crazy at all. I'm thinking a 20lbs reduction in unsprung weight would be HUGE for mpg.
    I have LRRs, Continental TrueContacts. It seems like everything's panning out:D
  8. 88Keys444
    37
    36
    illinois
    WEW that's heavy
  9. 88Keys444
    37
    36
    illinois
    Yeah I think it's worth shot to try it out. I replaced my stock tires with some Continentals, and combined they're 8lbs lighter than the OEM. I can say I have not seen a drop in MPG, which is shocking considering the old ones were bald with no traction. But after breaking in the new tires a bit, I've been noticing 1-2 MPG gains each drive without changing any driving habits. Pretty solid:)
  10. PriusCamper
    13,025
    5,293
    I'd love to see a link to super lightweight wheels that are affordable... I'm sure many others on here would too... Please share when you get a chance.
  11. 88Keys444
    37
    36
    illinois
    Sorry! I thought I already did.
    Here it is:
    https://www.discounttire.com/buy-wheels/konig-helium
  12. 88Keys444
    37
    36
    illinois
    So I have decided to do my own test on this since I'm tired of searching all over the internet:sleep:
    The question will be: Does reducing wheel weight increase fuel efficiency?
    After researching the true weight of my OEM 2013 Prius C wheel, I am SHOCKED at how much it weighs: 19LBS!!!!! Here is the link to it:
    2012-2019 15x5 Toyota Prius C Steel Wheel Rim- Road Ready - Road Ready Wheels - OEM Replica Wheel Supplier
    No wonder my acceleration is god awful. A buddy of mine has a 2013 Prius C as well, but I have the One and he has the Three, so he got lighter tires. Everytime I drive it, I notice his acceleration is EXTREMELY better. However, that is not what we're testing.
    I could ask him what his MPG is, but that doesn't prove anything since there is no control. His driving style is going to be different than mine, as well as distance, routes taken, amount of miles, etc. Way too many factors to consider.
    Current Tire/Wheel Setup
    Continental TrueContact Tour -
    175/65/15R (OEM Size)
    The current psi is:
    Front - 36 psi
    Rear - 34 psi
    Weight - 15lbs
    Stock OEM Wheels - 15x5
    Weight - 19lbs
    Weight each Tire/Wheel: 34lbs
    Total Weight: 136lbs :(
    Stock hubcaps are also on.
    "Upgraded" Setup
    The tires will be the same
    Weight per tire: 15lbs
    Total: 60lbs
    The psi will also be the same
    Aftermarket Wheels - Konig Helium
    Dimension - 15x6.5
    Weight - 11.1lbs
    Weight Each Tire/Wheel - 26.1lbs
    Total: 104.4lbs
    Difference in weight with Current vs. Upgraded - 31.6lbs
    Hypthesis: With such a huge difference in weight, the aftermarket wheels will improve MPG by a large amount.
    Less unsprung weight = less resistance = better fuel economy?
    Data will be collected for three weeks on each setup. Each drive will be logged.
    Variables to consider:
    The width of the Konig Heliums may affect MPG
    The aerodynamics will change with the Konigs. They do not block as much surface area as the stocks with the hubcaps on.
    I'd love to read what you guys think will happen. Will a reduction of 31.6lbs affect the MPG? Will wind resistance cancel it all out? Let me know!:D
  13. PriusCamper
    13,025
    5,293
    Also experiment with slowly adding 2-3psi in each tire and then back it off once you start to lose traction. ON my Gen2 Prius, which is a heavier vehicle, I get faster handling and way higher mpg with 47psi in front and 45psi in the rears... And my last set of tires I got 70K miles and near perfectly even wear even though the tires were only rated for 60K miles at 35psi.
    88Keys444 likes this.
  14. 88Keys444
    37
    36
    illinois
    Very nice! Any difference in the ride smoothness? I don't mind giving up a little bit of MPG for coziness, but I don't think I've experimented enough with psi
  15. roadrunner
    roadrunner His (blue) and hers (black).
    61
    36
    Perkasie, Pennsylvania
    2015 Prius c
    I have weighed the 15" steel wheels (15 lb), and the 15" alloy wheels (15 lbs). Both are w/o the tire.
  16. Mendel Leisk
    41,879
    I did somewhat similar with a 15" steel Corolla rim, except it had a mounted Michelin X-Ice tire. I weighed the whole thing, then deducted the tire weight, as listed on TireRack. Again, worked out to around 15 pounds for the rim.
    (I ignored the balancing weights, which would lower the rim weight more if considered. But peanuts? Also, how much more does compressed air weigh? More peanuts? And valve stem and tpms sensor.)
  17. 88Keys444
    37
    36
    illinois
  18. Mendel Leisk
    41,879
    Yeah I saw that link. Just for giggles: weigh them?
  19. 88Keys444
    37
    36
    illinois
    Sorry, I forgot I already posted the link. I have weighed them in the past and they are indeed 19lbs
  20. Leadfoot J. McCoalroller
    8,138
    7,642
    Pennsylvania
    2018 Prius c
    Hang on, you’re replacing 5” wheels with 6.5” wheels. That’s going to make a change too.
