Full charge dissipating by 1/3 overnight?
Discussion in 'Prime Plug-in Charging' started by JBLA7, Sep 1, 2019.
  1. JBLA7
    JBLA7 New Member
    LA
    2019 Prius Prime
    Hello,
    Per the title of this thread my full charge decreased by a 1/3 overnight it seems. Is that normal?
    My Prius prime is new (2019) with less than 2000 miles on it. This is the first time I've charged it up in about a month.
    Any help/input would be appreciated :)
    Thanks
    52,379
    welcome!
    did you leave it on by accident?
    by 1/3, can you tell us how many miles you lost overnight, or from what percent, down to what percent?
    if correct, no, it would not be normal.
    try it again and see what happens
  3. Clark_Kent
    Clark_Kent Member
    44
    39
    Atlanta, GA
    2020 Prius Prime
    Can you provide more context? Was it fully charged before you went to bed? Did you verify it was fully charged?
  4. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Car will shut off if you leave it on and then plug it in.
  5. bisco
    52,379
    what if you charge it up, unplug, and turn it on?
  6. VTBIGDOG
    211
    146
    According to the manual, the car will power down after an hour if it is in Park
  7. bisco
    52,379
    that's a nice improvement over pip!(y)
  8. JBLA7
    JBLA7 New Member
    LA
    2019 Prius Prime
    Hello all,
    Thanks for the replies :) I left it fully charged last night and woke up to a full charge this morning.
    Re the night prior I think I may have driven more than previously thought or perhaps I left it on. All seems well now tho.
    Clark_Kent and bisco like this.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    That sounds great, I'm glad you figured it out, I was betting on you saying something just like this.
    Rob43
    jerrymildred likes this.
  10. bisco
    52,379
    good news, all the best!(y)
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I know that it's 20 minutes in ACC or for one hour in ON mode. I don't believe it's true for READY mode, or there would have been a hue and cry from people wanting to camp like they did in the older models.
    VTBIGDOG likes this.
  12. VTBIGDOG
    211
    146
    What's the difference between on and ready mode?
  13. Tideland Prius
    16,615
    ON just runs the windows and the HVAC (just can) - think of it like an expanded Accessory mode. READY is when the car is able to drive off.
  14. jerrymildred
    11,517
    14,157
    Tampa, FL
    There is ACC, ON, and READY. Same as the key positions in a traditional car. My short-hand way of remembering is that one press of the power button without the brake pedal enables some stuff. The second press enables more stuff. The third press turns it all off. All I've ever used it for is just the one press if I want to open the windows after I shut it off and my wife has already opened her door. It's press, open windows, press, press. Done. Never for anything else.
    Tideland Prius and Rob43 like this.
  15. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    I think the manual mentions that after 20 hours in ready mode, weird things start to happen (but it doesn't shut off).
