Transmission
Discussion in 'Gen 3 Prius Technical Discussion' started by RoosterCody, Sep 5, 2019.
  1. RoosterCody
    RoosterCody New Member
    New York
    Please Help!
    I’ve been hearing a whining noise from the front of my 2010 Prius when accelerating and also when breaking. I have 122k on the odo. I bought this used with 110k. I have not had it long obviously. So I brought it in to toyota service and they said it needs a new transmission. No lights on and doesn’t drive poorly or slip. New transmission is 4,700 with labor. Is this a common problem? How come it drives fine and has no lights on etc.. could Toyota be wrong in diagnosis? Any help is greatly appreciated. I paid 5k for this 7 months ago I hate to see it go to waste. Thx
  2. Peter123
    Peter123 Active Member
    132
    128
    Transmission problems are rare in these cars. Did the prior owner change the fluid and put in aftermarket ATF? As a cheap fix, you could drain and refill the CVT with Toyota brand fluid. If that doesn't fix it, I would sell the car. There is a video on how to change the transmission fluid in the maintenance part of this forum. It is fairly easy to do it yourself.
    You might also want to get another opinion. Wheel bearings can also make noises from the front and that may be more likely.
    RoosterCody likes this.
  3. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    As the transmission is not a weak point of Prius, you may buy a used one, should be much cheaper than a new one from Toyota.
  4. ChapmanF
    18,501
    A bit of a "whining" noise is normal on a Prius just from the power electronics, which do switching at a frequency you can hear (and that varies with speed).
    As you haven't had the car very long, have you compared it to anybody else's Gen 3 Prius just to make sure what you're hearing is out of the ordinary?
    I'd hate to see all the bother of a transmission replacement just because a dealer saw an opportunity to respond to your question by selling you one.
  5. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    I would get a second opinion from another prius owner.
    The sound possibly may just be the regen from braking and electric from accelerating ?
    Maarten28 likes this.
  6. RoosterCody
    New York
    Thank you guys for all the replies. I am not sure what previous owner did as far as replacing fluids I only had records of oil changes she gave me. And as far as the whining noise it’s definitely a new noise not typical regeneration noise. My wife heard me coming down the block the other day that’s how mad it was. I going to try and see if it’s wheel bearing. I’m praying that’s what it is. I will keep you all posted. Thx again for responding
  7. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I would think it is a wheel bearing before I would suspect the transmission. There is no slip in the transmission as it is a constant mesh gear. There are no brake bands like in conventional automatic transmissions.
    CR94 likes this.
  8. GFO
    GFO Member
    75
    Larkspur
    Already stated above, but as a relatively cheap and not too difficult exercise to see if there's any change to the noise you're hearing, I'd change out the trans fluid.
    The previous owner(s) likely didn't do it as this is a common thing not to do on the 3rd gen and if the noise isn't from the trans, you're only going to do yourself a favor swapping out fluid with 120K on it.
    I did mine in my car port, used four jack stands to get the car almost level and it did a gravity fill from the top of the car using a funnel and thin hose. I used four quarts of Red Line D6, imo, it's a superior synthetic to the Toyota WS fluid, but it's perfectly fine to use the WS too. Some member here has changed his trans fluid multiple times now using Valvoline Maxlife ATF. which would be the most cost effective of the three. He claims he's had zero issues with it. Your car though, so your choice.
    Grit and edthefox5 like this.
  9. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Low on transmission fluid?
    Pixel XL ?
