Air only blows on driver side
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PVAFam, Aug 19, 2018.
  1. PVAFam
    PVAFam Junior Member
    Houston
    Three Touring
    Hey I'm guessing there is a broken motor or door somewhere in the dash. Anything I should try to get this working again? I've tried all different modes on the control panel and the top vents on the passenger side don't flow at all. Car is inside the garage 99% of the time so hopefully no critters making a house in there.
  2. PVAFam
    Houston
    Three Touring
    Tried to post a video, need a higher post count. The driver only mode doesn't make a difference.
  3. sclevine
    sclevine Active Member
    153
    149
    Northeast Florida
    2024 Prius
    If you are driving solo it is because there is a setting by default to only blow air on the driver. There is a button on the dash that toggles between blowing air on all the passengers or not. Just press that button and it should blow through all vents. If you have a passenger in the car with you, then sorry I can’t help.
    FuelMiser likes this.
  4. PVAFam
    Houston
    Three Touring
  5. bisco
    51,578
    when did it start? have you owned her since new?
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Is there anything blowing from the rear (floor) vents?
  7. PVAFam
    Houston
    Three Touring
    A little over a week, got the car CPO last year.
    Not sure, I would check but the car decided to fix itself on the way home from the store today.o_O
    kithmo, bisco, ETP and 1 other person like this.
  8. alanclarkeau
    7,045
    7,592
    Good - in a way - that it's fixed itself. I know a child like that - just when the doctor arrived.
  9. ETP
    2,802
    1,170
    Auburdale FL
    Mine constantly reverts to the driver only mode. I have to push the button down on the AC pannel to get it to normal. Also sometimes your system will go to outside air and another vent mode when it feels the need. Very irritating but it is supposed to be smarter than us.
  10. Nashanas
    Nashanas Junior Member
    Islamabad
    I am having the same problem with my Prius E 2016 model. So far I have not been able to resolve the issue. Any pointers will be helpful.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    There is also a setting on the Nav screen to turn heater efficient mode on and off, could be that.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Were you carrying a passenger ?
    Lovec1990 likes this.
  13. Lovec1990
    Lovec1990 Junior Member
    74
    Slovenia(EU)
    or any lagguage ?
    kithmo likes this.
  14. alanclarkeau
    7,045
    7,592
    Are you using AUTO Climate Control? What happens if you use the FAN switch to put it on full fan?
  15. Nashanas
    Islamabad
    No difference in AUTO or MANUAL MODE. Tried changing the driver priority settings etc. No change. Limited air blow on the right hand side vents. Normal airflow on the left hand side vents (center vent plus the one near the window). Looks as if one of the doors to right hand side vents is stuck so something similar and access to the evaporator box is extremely difficult. The whole dashboard is to be dismantled.
  16. 360texas
    360texas Member
    121
    35
    Fort Worth, Texas USA
    Ok I noticed the A/C air blowing on driver side only.
    Then on next local trip my wife sat in the right passenger seat then the air started blowing equally both left and right vents.
    Hmmmm thats logical and fair is fair. Happy wife happy life.
  17. alanclarkeau
    7,045
    7,592
  18. Nashanas
    Islamabad
    In my case, this S-flow mode is not working as mentioned in the manual. There is very little air in the vents on the right side (driver side in my case as I have a JDM right hand driver car). No error messages. All buttons on the ac panel give proper lights and corresponding displays on the dash screen.
