Gen4 Prius with Alpine Halo9 ILX-F309
Discussion in 'Gen 4 Prius Audio and Electronics' started by Mattheww, Jul 31, 2019.
  1. Mattheww
    Mattheww Junior Member
    25
    Kansas
    Two Eco
    I'm looking at having one installed in mine, but I can't picture how it will look in my head. Has anyone installed an Alpine Halo9 in a Gen4 Prius that can show me a picture of it?
  2. thomassster
    thomassster Member
    238
    Colorado, US
    2019 Prius
    XLE AWD-e
    considering no one has replied for some time, possibly no one has and youtubing of it on other cars is probably best.
    I remember some thread of someone installing these big screens and they do block the vents a bit, but the poster said it didn't bother them.
    Mambo Dave likes this.
  3. Mattheww
    25
    Kansas
    Two Eco
    I'm having mine installed on Monday and will post some pictures for anyone viewing this thread in the future. I'm also going to connect a Raspberry Pi 4 (4GB) to the HDMI output using this circuit. I'll be tapping into these empty fuses, I used a voltmeter to confirm.[​IMG]
  4. thomassster
    thomassster Member
    238
    Colorado, US
    2019 Prius
    XLE AWD-e
    Thanks for that info. I’ll consider it when I have to use those one day. Do you know whether the battery side is the top or the bottom where you circled ignition?
  5. Mattheww
    25
    Kansas
    Two Eco
    The driver seat is towards the left in the picture. The battery is towards the right, where ignition is circled.
  6. Mosfet
    Mosfet Junior Member
    Belgium
    2018 Prius
    Four Touring
    @Mattheww looking forward for pictures and hopefully any other details :D
  7. Mattheww
    25
    Kansas
    Two Eco
    The install guys mounted it too high, so its partially covering the vents. I'm hoping to have them remount it before I take those pictures.
  8. Mosfet
    Belgium
    2018 Prius
    Four Touring
    Sorry to hear that, hope that it will be an easy fix.
  9. Mosfet
    Belgium
    2018 Prius
    Four Touring
    @Mattheww got that issue fixed ?
    Still waiting for the picture :)
  10. Mattheww
    25
    Kansas
    Two Eco
    It's going back in to be adjusted this Friday. Here are some pictures of what it looks like now.
    thomassster likes this.
  11. thomassster
    thomassster Member
    238
    Colorado, US
    2019 Prius
    XLE AWD-e
    So what is your review on your new unit?
  12. Mattheww
    25
    Kansas
    Two Eco
    TL;DR: It's great, but nowhere near worth the price.
    Pros:
    • The huge screen with the backup camera is great.
    • Android Auto/Car Play. I'd consider it a must for any car after 2016. I have no idea why Toyota is taking so long to implement it. This was the main reason I replaced the stock stereo.
    • HDMI port. You could plug your Nintendo Switch, a DVD player, or your computer in.
    • Maestro RR. It costs ~$100 extra, but it's nice to see your tire pressure and other useful statistics of your car in real-time.
    • Brightness. I was worried that I wouldn't be able to see the screen, but it's not an issue at all. My windows are tinted to legal limit though.
    • Rear Camera. In other cars I've had aftermarket stereos installed on, it's taken too long to show the camera feed after shifting into reverse immediately after starting the car. There is no perceivable delay (imo) that is greater than the delay present in the stock stereo.
    Cons:
    • Price. I'm still having buyers remorse on this, months later. All these features are nice, but it wasn't worth it. Including discounts, the entire thing ended up costing $1,450, which is WAY more than I intended on spending.
    • Equalizer. It's so bad I don't even use it, I use the Poweramp equalizer on my phone as a work around.
    • Resolution. You can see the pixels from the headrest. For $1000 dollars, this is unacceptable.
    Oddities:
    • The install guys did not use the factory microphone, and now one is sticking out near my rear-view mirror. When I asked, they said that the factory microphone often has issues, so they don't use it.
    • There is a plastic rubbing against other plastic sound when the car is moving. I'm not sure if this is because of an install issue or if they all have this issue.
    • I'm having issues with the bass being way to quite, even with it cranked in the stereo settings. This may be caused by an issue i'm having with my subwoofer amplifier though. I should know for sure this weekend.
  13. thomassster
    thomassster Member
    238
    Colorado, US
    2019 Prius
    XLE AWD-e
    Wow, thanks for the review. The plastic rubbing noise can be improved by putting some dampening like thin speaker foam in between. I would recommend you inform your installers while they are touching those areas. The mic that comes with headunits are usually better than the factory mic. And trying to adapt the factory mic wiring to your head unit would introduce more noise. Not sure what the issue with your equalizer, but you should be able to add more bass by bumping up the levels on the low hertz rate on your equalizer. Sorry for your buyers remorse. There seems to be a markup on hdmi and I’m assuming you have wireless CarPlay/AA?
  14. Mattheww
    25
    Kansas
    Two Eco
    It does not have wireless Android Auto or Car Play, which is, again, ridiculous considering the price.
    The equalizer sucks because it puts humps on the points instead of just forming a line between two points. You can adjust the width of the humps, but it doesn't really help. The points are also locked between certain frequencies which is super annoying. I've tinkered with it a lot and haven't been as happy as just using the equalizer on PowerAmp.
    If I set the equalizer on PowerAmp to flat, adjust the bass to +10 in the settings and crank the stereo equalizer in the low ends, it still is underwhelming compared to before I had the stereo installed. I'm really hoping it's just my subwoofer amp, I've been having other issues that would indicate it's the amp too.
    I'll ask the install guys about it this weekend. Thank you for the advice!
