Cynlinder 4 is little weak
Discussion in 'Gen 2 Prius Main Forum' started by jack sparrow 111, Sep 10, 2019.
  1. jack sparrow 111
    jack sparrow 111 Junior Member
    los angeles
    my mechanic did the cylinders check where he inserts this gauge and gives him the power torque of the engine,,, Cylinder 1 2 3 were fine but 4 was little under the good zone... it initially had a misfire and it is fixed now but knowing that one of my cylinders is missing little torque, will this cause my engine to go bad in the long or short run ? i am trying to make a decision now whether to sell or keep it ...given that everything else now works fine and i have spent about 2,000 dollars fixing it this month, water pump, cluster rebuild, engine pump and so on....what is your opinion or advice ? i have 207,000 miles on it...
  2. PriusCamper
    PriusCamper Senior Member
    13,054
    5,304
    Pacific Northwest, USA
    Piston soak might improve things for a little while... Just google it to learn more....
    jack sparrow 111 likes this.
  3. jack sparrow 111
    los angeles
  4. ETC(SS)
    7,350
    Hard to say, really.
    Your car is already through much of its economic service life, but that cuts BOTH ways.
    LA Market.
    06.
    Hmmmm.
    I'd keep it for a while, although sight unseen I could defend either flag in this debate.
    It would depend on the street value versus how much you were willing to dump into another car (and it's problems!)
    The 06 is a VERY reliable car, so in the LA market and for somebody who is willing to fork out $2k to keep a 13 year old car on the road?
    I'd let the car pay you back for the money that you just put into it.
    If you get a year out of it you're better off than if you got rooked into making car payments again.
