Replacing o-ring on air assembly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, Sep 15, 2019.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    Hi Prius folks,
    Firstly, I don't know the correct name of the part. It's the O-ring that's on the hose that leads into the air assembly, you know, the box with the air filter. Is that the air assembly? Anyway I want to take it out so I can clean the throttle body, but I'm sure if I take the screw out that's on the o-ring, it's going to break. The car is running pretty well for 165,000 but I thought it would be a good time to clean the TB and MAF to try and keep things running smoothly. Do you think there's a generic clamp I can use, or should I go for the same type? So far the only one I've found is on ebay in this link:
    Toyota OEM Air Intake-air Hose Clamp 9611110880 for sale online | eBay
  2. Elektroingenieur
    2,515
    3,253
    Three Touring
    O rings are usually made of rubber, but from your description, I think you’re referring to the hose clamp, made of metal, that connects the engine intake air hose (no. 1 air cleaner inlet) to the air filter housing (air cleaner assembly). As shown in parts catalog Figure 17-03, Air Cleaner, this has Toyota part number 96111-10630.
    The list price for a new clamp is $4.60, so it’s probably not worth finding an aftermarket alternative.
    Skibob and bmparent like this.
  3. Patrick Wong
    18,199
    6,464
    If you need to use a generic clamp you could do so.
    bmparent likes this.
  4. bmparent
    bmparent Member
    159
    65
    barre ma
    Thanks for the link! That's the one. Hose clamp for air filter housing. I'll buy a real one.
    Elektroingenieur likes this.
