2015-2017 Prius V Redesign EGR / intake manifold fixed or same as 2012-2014
Discussion in 'Prius v Main Forum' started by hellonearth, Sep 13, 2019.
  1. hellonearth
    hellonearth Junior Member
    35
    I was just curious if Toyota fixed the EGR / Intake Manifold issues on the Prius V (Wagon) redesign 2015-2017. Not sure if it was just a cosmetic update with some structural changes to fix the IHS crash test ratings. I have a 2012 Prius V and had to have the EGR service done at 92k the dealer which cost over $700 and was wondering if they ever fixed it
    Also would the 2016-2017 Rav 4 Hybrid or the 2011 - 2016 Highlander Hybrid have the same issues as well. Our Lexus CT200h is getting a little cramped for us so am mulling over options for the second car
    Thx
  2. hellonearth
    35
    So I guess no one knows
  3. Air_Boss
    Air_Boss Senior Member
    3,908
    1,064
    New Yawk
    There was a note that the piston rings were redesigned on 2015 onward, which may mitigate the egr issue.
    #3 Air_Boss, Sep 15, 2019
  4. Mendel Leisk
    38,207
    McGeorge Toyota Parts links to EGR parts:
    2012 Prius v:
    EGR System for 2012 Toyota Prius V | McGeorge Toyota Parts
    2015 Prius v:
    EGR System for 2015 Toyota Prius V | McGeorge Toyota Parts
    The pipe, valve and cooler have the same part numbers. The official names are a little different, for example what's commonly described on PriusChat as "cooler" is referred to as "pipe", and similarly the "pipe" is called "tube", but yeah.
    So the parts are identical, which leaves maybe only programming differences? Which I kinda doubt.
  5. hellonearth
    35
    Thank You. This is really helpful!
