04 Prius red triangle with exclamation point car won’t start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by samsubarany, Sep 15, 2019.
  1. samsubarany
    samsubarany New Member
    Fresno CA
    0E4FFF04-61E3-43F7-9D80-363FADB97AD5.jpeg BAA485AA-A2D2-40E0-8861-D0E0915210C3.jpeg I have a 2004 Prius with a red triangle of death along with an yellow exclamation point next to it and a pinkish car symbol with a exclamation point on the screen top left corner. It will start intermediated when u let it sit couple hours and nothing will show on dash till couple minutes of letting it idle or driving it. No check engine light on the dash. When the red triangle appears on the dash if I turn off the vehicle and try to restart it, it would not start. I’ve took the hybrid battery out and tested it individually and it’s all consistent with 7.85-7.87v. 12v battery reads at 11.8v with vehicle off. Please help.
    48,862
    welcome!
    you need a new 12v
    check the inverter fluid reservoir for movement
    you have to load test the hybrid battery
  3. samsubarany
    Fresno CA
    I will replace the 12v battery and if that doesn’t work then I’ll do the load test as u stated. Thanks for the help
  4. jerrymildred
    jerrymildred Senior Member
    11,490
    14,095
    Tampa, FL
    Your 12V is low, but it should still start at 11.8V. My Gen 2 started with as low as 8.5 volts.
    I would charge that battery and try it again before throwing money at it. You may or may not need a new one. Proper testing will tell you. But I think you'll still have to read the codes to find out the real problem. But, as @bisco said, checking the inverter fluid for movement is an easy test -- after you get the car to start.
  5. 3PriusMike
    2,933
    2,286
    Silicon Valley
    All these nonsensical icons show how dumb the UI design is in modern cars. With all the screen space and memory available could they not display a message in plain English or whatever language the drivers prefers along with the icon...and an error/warning message number?
    The answer is no they can not, else the dealer maintenance departments will be upset.
    Mike
    jaw444 and strawbrad like this.
  6. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    993
    Bisco is responsible for the needless replacement of hundreds of 12 volt batteries. There is not enough information here to warrant replacing the 12 volt battery.
    Taking apart the HV battery without first reading codes is simply foolish.
    The fact that the car will run after cooling down does suggest a failed inverter cooling pump.
    Skibob, JC91006 and jerrymildred like this.
  7. bisco
    48,862
    i secretly work for exide :sneaky:
    jaw444 and Raytheeagle like this.
  8. samsubarany
    Fresno CA
    The electronic water pump is test while car is running and yes it works. There is no check engine light so code reader cannot detect anything. I’ve replaced a new 12v battery today and still have the same issues was reading 12.3v. I was told to check the isolation fault for a cell leak. That would be my next step as they said it will not trigger the check engine light just yet because the leak is slow.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,474
    Bay Area, California
    2019 Prius Prime
    It all makes sense:p.
    3PriusMike and JC91006 like this.
  10. jerrymildred
    11,490
    14,095
    Tampa, FL
    This statement makes no sense whatsoever. The red triangle is jumping up and down, waving its arms and screaming, "Read the codes. I have a problem!" So read the codes. The triangle's sole purpose is to tell you that there is a fault.
    Of course you have the same issues, because, as I said, an 11.8V battery won't cause any problems. Quit wasting time & money by guessing and read the codes.
    strawbrad and JC91006 like this.
  11. strawbrad
    953
    993
    There certainly are codes that triggered the red triangle and the car with a dagger light. Your code reader just cannot read them. Techstream is Toyota's official software that reads all the codes. You need an old Windows laptop and a Mini VCI or VXDIAG cable to use it.
    Bisco's latest victim.
    A proper code reader will detect an isolation fault. There are simple but kinda dangerous tests to find isolation faults using a voltmeter.
    An isolation fault will keep the car from restarting. Disconnecting the 12 volt battery clears the code and allows the car to start. Does this match what you see happening to your car?
    jerrymildred likes this.
