How do you change the bulb at the bottom of the 2 front doors?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Sep 17, 2019.
  1. ski.dive
    ski.dive Active Member
    965
    244
    Hutchinson Island,FL. Mt. Snow,VT
    I cant get the clear plastic cover off the door, to change the bulb????
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Thin blade (…it doesn't need to be sharp! …it doesn't even need to be made of metal) …take care not to damage the locating tabs! - Good luck!
    Here's what I replaced mine with:
    #2 WilDavis, Sep 17, 2019
    Salamander_King and Raytheeagle like this.
  3. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    @ski.dive
    What is the failure mode you are experiencing when you attempt to pry off the lens? It is generally better to pry at the bottom center of the lens. Perhaps a previous owner broke the lens in an attempt to remove it, and glued it in place? Unless you are the original owner. If it's glued in place, you will have to remove the entire door panel to replace the bulb. Do you see any evidence of glue?
  4. Salamander_King
    Salamander_King Senior Member
    11,023
    8,959
    New England
    Very cool! Where can I find it?
  5. TGrracie
    TGrracie Member
    45
    43
    Duxbury
    2018 Prius Prime
    I have that on my Prius Prime and I love how it looks!
  6. ski.dive
    965
    244
    I tried to remove it,but it was not coming off easy, I then stopped & asked questions on removal.
    *No glue on the plastic lens cover 'original owner'
  7. WilDavis
    2,493
    2,155
    49
    Amazon:
    Skibob and jerrymildred like this.
  8. Salamander_King
    11,023
    8,959
    New England
    Cool! Thanks. Not very expensive. Just wondering if this particular one fit on PRIME?
    Did you buy the same one as @WilDavis for your PRIME?
  9. TGrracie
    TGrracie Member
    45
    43
    Duxbury
    2018 Prius Prime
    Yes, I did
    Salamander_King likes this.
  10. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    It says 2010 and up (gen 3). What year car do you have them in?
  11. WilDavis
    2,493
    2,155
    49
    2009 Gen II…
    Skibob likes this.
  12. Skibob
    2,912
    1,505
    Northern California
    Thanks. Just wanted to make sure. Description says 2010 and up.
