13 Prius - EGR pipe gasket (intake manifold side) - part number?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pingd, Sep 17, 2019.
  1. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Would anyone know the exact Toyota part number for a 2013 Prius Two, the SMALL orange gasket between the EGR tube and intake manifold? (i.e. NOT the main intake manifold gasket (series of rings))
    I can't find it listed on any parts diagram.
    It would be here, to the left of #5:
    Genuine OEM EGR System Parts for 2013 Toyota Prius Two - Olathe Toyota Parts Center
    Or maybe here, on the upper righthand side of #32:
    Genuine OEM Engine Parts Parts for 2013 Toyota Prius Two - Olathe Toyota Parts Center
    Thank you!
  2. Mendel Leisk
    41,824
    I think it should be on the page with the intake manifold:
    Except it isn't: there's the gasket between intake manifold and engine (item 33), but not the little one between intake manifold and the EGR pipe. Which is a little maddening.
    Ok, this straight-from-Toyota site has it, good to check when the dealership sites fail:
    MANIFOLD. 2013 Toyota Prius Two HYBRID | Toyota
    Direct link to the part:
    2013 Toyota Prius Two HYBRID Gasket, egr inlet. System, exhaust, engine - 2562828010 - Genuine Toyota Part
    Soh and Raytheeagle like this.
  3. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Outstanding Sir Mendel of Leisk - both for the exact P/N and "Toyota Parts Golden Source Website" - Thank You Kindly!
  4. Mendel Leisk
    41,824
    You're welcome. @Elektroingenieur kept linking this site, not as "friendly", sort of last-resort, but has a lot more of the small parts, fasteners, gaskets.
  5. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Summary (2013 Prius Two)(probably the same for all Gen 3 YMMV):
    EGR Inlet Gasket (intake manifold side): Toyota 256282-8010 ----- Fel-Pro 72694
    Throttle Body Gasket: Toyota 22271-37010 ----- Fel-Pro 61711
    In the end, I went with the Fel-Pro ones because when factoring in shipping (or going direct to the local dealer) it was about $20 total (0-7 day wait) vs $8 total from O'Reilly Auto Parts (and only 1 day wait).
    Soh and gliderman like this.
