My Car was Honking while Charging
Discussion in 'Prime Plug-in Charging' started by mrdata71, Sep 17, 2019.
  1. mrdata71
    mrdata71 Member
    37
    US
    2026 Prius Plug-in
    XSE Premium
    Hello all you fellow Prime owners.
    My 2017 Prius Prime Advanced started Honking while Charging last night.
    Never did this before.
    The OEM Charger was plugged into a GFCI Outlet.
    It was charging from it being fully depleted, and is back to 35 miles.
    Anyone have this happen before, and was it from the GFCI outlet?
    Thank you In Advance!
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,963
    New England
    Was you car locked? Maybe someone pushed panic alarm button on the fob?
  3. bisco
    52,354
    that means it was really enjoying the electrons you were feeding it :cool:
    noonm likes this.
  4. mrdata71
    mrdata71 Member
    37
    US
    2026 Prius Plug-in
    XSE Premium
    My Car was locked, and in the garage. My Key Fob was on my nightstand and I was in my bed asleep.
  5. Salamander_King
    11,024
    8,963
    New England
    By "Honking", you mean the horn was sounding? Did it stop on it's own or you had to stop it? If you had to stop it, how did you stop it?
  6. mrdata71
    mrdata71 Member
    37
    US
    2026 Prius Plug-in
    XSE Premium
    I used the Key FOB to stop the honking. The Lights were blinking like it was the alarm, but as I stated, it was in the garage.
  7. Salamander_King
    11,024
    8,963
    New England
    That sure sound like false alarm to me. I think the charging has nothing to do with it. Something must have triggered the security alarm (panic mode), though I have no idea what.
    #7 Salamander_King, Sep 17, 2019
  8. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    You get 35 miles (indicated) on a charge??
  9. Salamander_King
    11,024
    8,963
    New England
    35 miles is not hard to accomplish. My GOM has been showing over 40 miles (indicated) and over 40 miles (actual) EV range on a full charge for several weeks now.
    jerrymildred likes this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    While it's so hot here, I usually show a predicted 33-34 miles. When our weather eventually cools back down (Please God! Let it finally cool back down. :cry:), it will usually show 35-38 miles.
  11. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    I am rally confused now. I get about 22 to 24 miles indicated (24 at home, 22 at a free charge Point charger). Nothing near the 30 - 40 shown here. Are we talking about the same thing?
  12. bisco
    52,354
    it's all based on your driving history. you can't compare to others
    like mpg, it depend on how you accelerate, speed, hills, climate and etc.
  13. jjs357
    jjs357 Junior Member
    Near Philadelphia PA
    2020 Prius Prime
    I have a 2020 Prime Limited that I bought in August. Living and driving in the West Philly suburbs. After the first few charges when the GOM was low, I am now seeing an EV range of 33 to 34 miles. This has been a pretty accurate prediction for me.
    I usually drive with the AC off, windows open. Not many expressway miles. Soft acceleration but I keep up with traffic and speed limits.
    And the GOM has been rising still after each charge. But nowhere near 40 miles for me.
    Of course Fall and eventually Winter is coming to Eastern PA...
  14. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    If you drive like the accelerator and brake pedals are made of redhot bricks and the A/C-Heating is verboten, its doable.
  15. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    I guess we ARE talking about two different things. I though we were talking about INDICATED range. Actual range depends. On a frequent 20.1 mile route from about sea level to 1500 feet on a narrow steep mountain two lane I run out of electricity just before I get there, going home i have 12 mile of range left.
  16. jerrymildred
    11,517
    14,157
    Tampa, FL
    I'm talking about indicated range. Actual range is harder to measure since, if I'm going beyond range, I'll probably switch to HV mode before range depletion. If I'm not going beyond range, then I don't really know how far I could have gone. It's very rare that I'll start out in EV and stay in EV till it runs out. I like to use HV for the higher speed portions and EV for the lower speeds.
    As for driving styles, I kind of have to go with the traffic when there is traffic. If no traffic, I mostly follow the advice of the HSI. Unlike most people on our roads, I am aware that there are positions for the throttle between off and WOT. Intelligent braking is probably the biggest factor. Last second braking is like throwing money out the window.
  17. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    I'm talking about both. As I understand it, the GOM's indicated range is based on your historical actual range (or more specifically your estimated mi/kWh). So, if you're regularly getting 30-40 mi in actual range, it'll translate into the indicated range being in 30-40 mi territory.
