OEM incandescent license plate bulbs singed the socket!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Robert Holt, Mar 16, 2018.
  1. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    image.jpeg An OEM rear license plate illumination bulb burned out after 5 years on my 2012 hatchback. When replacing it with an LED version I was surprised to notice that the gray plastic socket was discolored and slightly melted around the base of the bulb. So I pulled the other license plate illumination bulb out and found the same situation (see picture). I have now replaced both bulbs with slightly lower wattage but brighter and whiter LED versions, and hope that the total heat dissipated will be enough lower that the plastic sockets will not deteriorate any further. But especially if you have an older Gen III with the OEM incandescent bulbs, you might want to check those sockets at some point. On the 2012 and newer hatchbacks with the two rectangular plastic access panels for the license plate bulbs, this remove and replace operation is quick and painless should you decide to change the bulbs.
  2. Mendel Leisk
    41,826
    My 2010 also m has rectangular lids you pop out, on the inside of hatch. Not sure that it's any different from the 2012 onward?
    I've had to replace a couple of bulbs so far, but so far haven't noticed any overheating. Thanks for the heads-up though.
    These bulbs don't seem to last long, btw.
    Robert Holt likes this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  4. Robert Holt
    1,313
    889
    I watched a YouTube video for the license plate bulb replacement where those rectangular lids appeared to be absent and the gentleman removed the entire plastic interior cover of the hatch to get at the bulbs. Thus I was unsure which Gen III years and models had those rectangular pop-out access lids and which did not. My bulb lasted 75,000 miles and almost exactly 5 years, so I cannot complain, but I prefer the illumination of the LED type of bulb and rather hope they will last longer.
  5. Mendel Leisk
    41,826
    I wonder why some would heat up? Defect?
  6. Robert Holt
    1,313
    889
    Jimbo, I installed those in my front parking light sockets and they certainly improved the parking light illumination in front! I did have one fail after about 2 years (?) though, but I bought them in a package of 4 so no problem. Have you replaced the amber front side marker lights with LEDs by any chance?
  7. Robert Holt
    1,313
    889
    Not sure, but on my vehicle, the bulb sockets on both sides of the license plate holder were about equally singed, which makes me doubt a defect and simply suspect the high heat output of the OEM bulbs (hence the warning). Incandescent bulbs typically waste 90% of the input wattage as heat, but the heat can be dissipated by radiation, conduction, or convection, so the bulb and the exact design of the socket and enclosure can play a role. The LEDs typically have less wasted wattage overall, but my understanding is that they dissipate much less by radiation and commensurately more by conduction particularly at the base of the bulb, so I'm really just hoping that the net bottom line is less heat being put into that gray plastic socket. I'd rather not have to replace that socket at the next go-round!
  8. Mendel Leisk
    41,826
    Other possibility: moisture getting into the socket? I'm not sure, just speculating.
    Walking the dog at night, I notice a lot of vehicles with dark rear license plates (or one of the two bulbs out). A lot of people neglect to check these bulbs, and there's no longer inspections here. Progress... :rolleyes:
    #8 Mendel Leisk, Mar 16, 2018
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    No I still have 2 spares, I wish I could replace the rear marker lights, but Toyota does not hint they are owner serviceable.
  10. Robert Holt
    1,313
    889
    Mendel: Another possibility is that the incandescent bulbs burn both brighter and hotter just as they are ready to burn out (increased resistance and energy consumption) , and that is the process that was melting the license plate bulb socket. We use parking lights on all days except direct sunshine because our gray Prius is almost invisible on cloudy days on gray pavement. If correct, this implies that other folks who are replacing burned out OEM license plate bulbs should have noticed the same melting, at least if they were in the warmer southern parts of the US.
  11. rjparker
    10,412
    6,521
    I am seeing the same problem on my 2012 Prius v license plate bulb socket. I do run with the lights on all the time.
    Apparently plenty of others need them as well. Part 90075-99011 which may be less at the dealer since this ebay price includes shipping.
    #11 rjparker, Sep 13, 2019
  12. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,497
    2,482
    Taylors, SC
    Might find it here...…….
  13. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    No, increased resistance would result in less energy consumption and reduced brightness. However increased resistance at the bulb base contacts might result in the base becoming hotter (and reduced brightness of the filament).
  14. rjparker
    10,412
    6,521
    There is no doubt my bulb socket has poor contacts that were heating it up. In fact the socket is intermittent right now until I get a new one.
  15. Peter123
    Peter123 Active Member
    132
    128
  16. Georgina Rudkus
    3,497
    2,482
    Taylors, SC
    I have had great success with these;
    I installed them in my Prius v including the license lamps as well as my husband in his 2016 Nissan Versa Note. They have been working for nearly three years with absolutely no issues.
    They are as cheap as incandescent bulbs and just work. I am sold on them.
  17. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I just tried some LED bulbs that I bought last year, but they are too long and hit the glass before the holder is seated properly -- and, like so many that I see advertised, they have small LEDs around the sides of the non-transparent cylinder, so much of the light is wasted anyway.
  18. Georgina Rudkus
    3,497
    2,482
    Taylors, SC
    The ones that I got off of Amazon works and still works after nearly three years. There are no fitment issues.
  19. MikeHawk69
    MikeHawk69 New Member
    Phoenix, Arizona
    I have put LEDs through out the cars interior & exterior ... try those
      File size:
      49.7 KB
  20. MikeHawk69
    Phoenix, Arizona
    Also, I've been told by a few Toyota parts guys that these burn out fast cause of the heat & tight area they are located. Not enough ventilation. LEDs produce much less heat & use much less power.
