1. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Ok peeps what's best solution for cleaning up a very clogged ever cooler,I've tried brake and carb cleanercalso left to soak for a couple of hours in a parts washer but still not really happy with results.
    Anyone tryed oven cleaner or anything else?
  2. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Oven Cleaner (get the heavy duty version) works well. Plug up one end of the cooler, spray in the oven cleaner. Wait. Rinse. Repeat.
  3. ASRDogman
    ASRDogman Senior Member
    7,541
    3,893
    I use oven cleaner. Soak it good from both ends and let it sit for 30 minutes or so.
    Then use a pressure washer to clean it out. I didn't think about the pressure washer until someone
    mentioned it. Sorry, can't remember who though. :(
    If it's really clogged, you may have to do it several times. Some run a thin welding rod between the fins.
    Just be careful NOT to damage the fins, or you could have a coolant leak.
    There are several different methods. If you have access to a glass beader that would also work.
    You could go online and do a search for the egr cooler, and should find several junk yards in different
    state. I purchased one for $50 I think it was, including shipping.
    Raytheeagle likes this.
  4. taxidriver50005
    204
    170
    GB
    Excel
    Cheers guys,note to self check out post before posting.....ever cooler or egr cooler DOH!!!
    Should you be able to see right through when cleaned
  5. ASRDogman
    7,541
    3,893
    The cooler is just like a radiator. You should be able to see through/between the tubes.
    You can shine a flash light through it.
  6. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Oven cleaner is very alkaline, if the cooler is made from aluminium it might be a bad idea.
  7. Ed Beaty
    334
    311
    Salt Lake City
    The cooler proper is all stainless, only the valve body is aluminum; just stay clear of that...
  8. Mendel Leisk
    41,315
    I used OxiClean on the EGR cooler, somewhat similar to oven cleaner, in that it's quite basic (caustic) albeit not as much so. Also more benign, won't burn your hands. I mixed powdered OxiClean with hot tap water, as much as I could dissolve plus a bit, swirled it good and shot into the cooler with a cork at the south end. Wait an hour while it bubbles, pour out and rinse well, then repeat. Five or six times thus it was very clean.
    That said, it was pretty low miles when I did this. More clogged cases in particular, a light-duty pressure washer jet is supposedly a good persuader.
    And for the (aluminum body) EGR valve yeah, avoid Oxi, just use something like carb or brake cleaner with brushes. Be careful of the electronics too.
    Oxi works pretty good on the intake manifold too.
  9. Threej
    Threej Member
    99
    99
    Portland, OR
    When mine was clogged, I tried break parts cleaner, oxyclean, oven cleaner, and seafoam. None of them really do much if you're already clogged. The only thing that worked for me was plunging each of the passageways with a thin coat hanger.
    Once I got 70% of the gunk out that way, I did 6 more oxyclean soaks to get out the last 30%
    Robert Holt, mjoo and Mendel Leisk like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Go for the pressure washer ;).
    It’s the right tool for the job (y).
    Chris Loyd and RMB like this.
  11. Mendel Leisk
    41,315
    @taxidriver50005: BTW, was the thread title supposed to read "EGR Cooler"?? I do mental aerobics every time I read it, think the threads about ground-effects package, AC, or summit. (n)
    If so, you could report it, and ask mod to fix.
  12. taxidriver50005
    204
    170
    GB
    Excel
    Right found a spare afternoon to sort out mine and wife's EGR cooler, pressure washed first followed by 30 minutes soak in oven cleaner and then another 10 minutes with pressure washer.
    Pleased with results as mine was blocked solid, tryed filling one end with carb cleaner left for 20 minutes and the other end was still dry.
    Robert Holt, RMB, mikey_t and 2 others like this.
  13. ASRDogman
    7,541
    3,893
    NIFTY! Now I want to clean my spare!
    taxidriver50005 and RMB like this.
  14. Cban
    Cban Junior Member
    Chicago
    I used a combo of things. I tried carb cleaner at first that did nothing because of the severity of the clog. I then tried a soak with purple power for 4 hours then pressure washed it. That opened up the cooler to about 30 percent.
    After that I did soaks with Easy Off oven cleaner and pressure washed for a few cycles and that got it pretty much open.
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Looks a lot better;).
    Glad the pressure washer opened it up and it’s sorted now(y).
    Cban likes this.
  16. ASRDogman
    7,541
    3,893
    Easy Off oven cleaner and pressure washer is a good combo! :)
    Cban likes this.
  17. Bbonez
    Bbonez Member
    40
    44
    How many miles did the car have when you took those pictures? And what year is your Prius, if you dont mind me asking.
    Good job on the cleaning, I am waiting for the weather to be nice on one of my days off then I'll be attempting this as well.
  18. Bbonez
    Bbonez Member
    40
    44
    Duplicate post
  19. Cban
    Cban Junior Member
    Chicago
    It's a 2010 with just under 160,000 miles on it. The cooler was completely clogged and my car threw P0401 code. I cleaned the EGR PIPE the same way cause it's stainless steel too. But I learned the hard way of using the caustic cleaner on the EGR VALVE because the metal reacted and started forming this white gritty film on the surface. I wish I read Ed Beaty and Mendel Leisk comments before doing it. I immediately rinsed and soaked the EGR valve in highly acidic white vinegar and that neutralized the reaction. It seemed to just effect the surface, the internal parts were all fine. Good luck with the cleaning. Just have to be persistent and it will open up.
  20. ASRDogman
    7,541
    3,893
    Baking Soda power would work too. :)
    Cban likes this.
  21. meeder
    239
    163
    Has anyone tried an ultrasonic cleaner for the EGR cooler?
    Verstuurd vanaf mijn LYA-L09 met Tapatalk
