Turtle uphill and Hybrid system overheat... please help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shahzad Nayyar, Sep 19, 2019.
  1. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
    Hello to all. I have been a low key guy who had been going through forums and bemefitting a lot from this app. At present i am at a hiatus and totally lost. Here goes
    I have a JDM 2015 prius which has 74k Km on it. Bought it last year. The car is a beauty. Everything perfect. I live at an altitude of 2500 ft and there's an ascent near my house which takes up to a height of 9500 ft on one hour. When i got my prius i would just go up and down the hill with four adults in the car and the car would not mind. However, somewhere around june, the car showed considerable hesitation on the drive after 8000 ft elevation. The traction battery had 3 bars and the engine was revving only till about 1900 rpms. It did not want to rev more. The last stretch of 500 m, i traveeled at 20 Kmph. Now thag was embarrasing. I started checking stuff. Everything was fine. Inverter coolant had turbulence. ICE did not over heat. 12 v terminals were a bit loose but tightening them did not help. I tried putting in Fuel inj cleaner from Liqui moli, cleaned the air filter, maf sensor, throttle body but the problem persists.
    Today when i went there, the car started slowing down even at 7700 ft. And after 3 mins of driving like a turtle, i got the hybrid system overheat. I immediately stopped the car and checked the inverter coolant. There was turbulence. Torque showed it was revving at 4755 rpm. I didnt know what to do so i did something that i probably shudnt have. I opened the cap of the ICE coolant tank. There was a gush of gas leak and guess what the hybrid overheat sign went off. The car drove normally after that. But after 5 mins.... Turtle mode again.
    I ise 0w20 liqui moli. I am totally confused. I have bothered Patrick Wong A LOT. I must say that he is the most genuinely helpful guy i have ever come across. But i have run out of ideas. There are no codes at all. Help please. Thanx
  2. Shahzad Nayyar
    94
    25
    Pakistan
    The engine coolant was at around 97 c while inverter coolant was at 60 c
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    First, I'm not extremely familiar with Gen 3. But...
    Is there a chance your "overheat" warning is actually for the HV battery? Maybe the fan is clogged or the air path is clogged? Is there an intake filter/screen somewhere near the floor on Gen 3s?
    Is torque able to display battery pack temperatures? Does it display DTCs?
  4. mpg_numbers_guy
    116
    64
    VA
    Sounds like the hybrid battery pack overheated - pull it apart and clean the fan and surrounding area, then report back. Probably wouldn't hurt to do a Dr. Prius hybrid battery test just from how hard the battery is being used.
    Any check engine light?
  5. bisco
    52,258
    what was the ambient temp?
  6. Shahzad Nayyar
    94
    25
    Pakistan
    No check engine light. I had checked the fan. No obstruction. One of my kids is always on-duty with the fan. The fan does show variable speed
  7. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    How stable is the engine coolant level?
    What about the engine water pump?
    What code reader do you have?
  8. Shahzad Nayyar
    94
    25
    Pakistan
    On motorway, the car would go 180 kmph with 2 adults, 2 kidd and luggage without any issue but here on mountains there r issues
  9. Shahzad Nayyar
    94
    25
    Pakistan
    One more query. Where does the hv fan let air out? I mean there is a vent in the trunk when u remove the xtra storage bin but where does it go from there?
  10. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Check the hv battery. Check cell groups voltage
    You can use hybrid assistant. With it you can also manually control the fan speed
  11. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Obviously a pack overheat issue here.
  12. Shahzad Nayyar
    94
    25
    Pakistan
    Any idea about that. What if somehow the outlet is being obstructed?
  13. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    The duct exiting the battery just vents to the area around the plastic tray, then flows toward the back of the car where there are outlet louvers on each side of the car.
  14. Shahzad Nayyar
    94
    25
    Pakistan
    Well no blockade to the fan. The fan itself, not 100% clean but was causing good flow 20190920_165433.jpeg 20190920_165425.jpeg
  15. bisco
    52,258
    a good hybrid battery with a good cooling system can still go into battery protection mode in warm climates and steep hills
  16. Shahzad Nayyar
    94
    25
    Pakistan
    But it worked fine on that climb last year with similar load
  17. Shahzad Nayyar
    94
    25
    Pakistan
    Can it be that the ICE is not performing upto the mark causing the HV battery and inverter to overwork and get overheat?
  18. bisco
    52,258
    maybe you need tech stream. torque misses a few codes if i'm not mistaken
  19. Mendel Leisk
    41,804
    That's an extreme workout for any car, would tax it near the design limits. Both going up (obviously) and coming back down. Is this a near-daily event? Do you shift to B for the descent?
  20. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    What’s ICE temp when car limps?
    mjoo likes this.
