A HYBRID BATTERY PACK CAGE MAYBE NEEDED!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dxta, Sep 20, 2019.
  1. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    I just read an article this morning, about a surprising phenomenon of hybrid battery pack theft around the San Francisco area.
    Thieves in this case, broke into a lady's 2017 prius parked down within the neighborhood, without breaking opening the doors, but had cut through the back, destroyed the battery harnesses, cut seat belts, and left. Obviously they'd sale them in the opened market.
    This is similar now with thieves stealing catalytic converters everywhere.
    Maybe I'd suggest people something like a small cage made enclosing the pack entirely?
    Thieves in San Francisco target Toyota Prius battery packs | Autoblog
    #1 Dxta, Sep 20, 2019
    Prodigyplace likes this.
  2. Prodigyplace
    12,526
    11,747
    Central Virginia
    Correction. It was a 2017 Prius not a 2019.
  3. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Thanks so much! Corrected already.
  4. Leadfoot J. McCoalroller
    8,068
    7,552
    Pennsylvania
    2018 Prius c
    I don’t see a cage helping, unless it were a very big one with the whole car inside it.
    The thieves would still cause a lot of damage on their way to discovering a cage around the battery.
    scona and Prodigyplace like this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    How hard is it to activate the car alarm? Don't most modern cars have alarms from the factory? Certainly someone busting into a car would set it off.. I realize a thief can be pretty quick, especially a group, but dang...
  6. bisco
    51,839
    trunk monkey...
    Skibob and Diemaster like this.
  7. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    I'm thinking, there must be some kind of collaboration within that environment where the car was parked.
    It's just baffling.
  8. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    A cage would sure help.
    I have seen where even 12V batteries were stolen from conventional car's. The thieve gets access from the front grille side, and unlocks the hood from there.
    With that rate of battery theft in some parts of Lagos, some car owner have modified the battery housing with a cage enclosing it.
    Even heavy duty trucks have their batteries caged that way.
  9. Prodigyplace
    12,526
    11,747
    Central Virginia
    Not the Prius in any trim I can remember
  10. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Well, I learned something new today. This is from a 2007 Owners Manual. So if I understand this correctly, once the car is locked, if any door or hood is opened without use of the FOB, SKS or key to unlock it, the alarm sounds. Bust a window to do a smash and grab..no alarm. Bust a window and then open the lock from the inside to remove a battery.....? idk....
    Theft deterrent system
    21p028a
    To deter vehicle theft, the system is designed to sound an alarm if any of the doors or hood is forcibly unlocked or the battery terminal is reconnected when the vehicle is locked.
    The alarm blows the horn intermittently and flashes the headlights and tail lights and other exterior lights. This function can be deactivated or activated. For details, contact your Toyota dealer.
    nvm, just found this....
    Never leave anyone in the vehicle when you set the system, because unlocking from the inside will activate the system.
    I like this last part...a lot. Think I'll try this with the wife next time she wants to wait in the car while I run in the house or store real quick. Roll the windows down, hop out, lock the doors. Go inside and then call her and tell her she needs to come in for a minute to look at something. She how far she jumps when she opens the door and the alarm goes off..:sneaky:
    #10 TMR-JWAP, Sep 20, 2019
  11. Prodigyplace
    12,526
    11,747
    Central Virginia
    Do you also have a cozy doghouse to live in? ;)
  12. Leadfoot J. McCoalroller
    8,068
    7,552
    Pennsylvania
    2018 Prius c
    From the linked article, I think the victim has the right response. She obviously intends to continue living and/or working in that neighborhood, so she’s getting rid of the car and switching to public transportation.
  13. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    I just feel her pain so much! Getting rid of a 2017 Prius because of what happened. The price she might get it sold would be ridiculous.
  14. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    I second the trunk monkey.
  15. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Second the monkey? This would be against gun laws in that area then:D.
    But wait! Is this real, or some kinda humorous stuff? What if a thieve knew there was a monkey in there? They'd kill it.
  16. Skibob
    2,912
    1,502
    Northern California
    You can have a shotgun in Oregon. California too. You do have to be impressed with his tire iron skills. :ROFLMAO:
    Dxta likes this.
