HV Battery fault
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bazzy, Sep 21, 2019.
  1. Bazzy
    Bazzy New Member
    Ireland
    I am new to the hybrid world I inherited a 2006 prius with 253987 kilometers on it
    The dash was also lighting up like a christmas tree
    I scanned it and got the POA080 error
    I've stripped out the battery and went across the packs with a mulitmeter
    I'm getting the following values
    1 8.21
    2 8.23
    3 8.22
    4 8.24
    5 8.24
    6 8.23
    7 8.24
    8 8.23
    9 8.23
    10 8.22
    11 6.98
    12 8.22
    13 8.23
    14 8.22
    15 8.23
    16 8.23
    17 8.25
    18 8.24
    19 8.25
    20 8.22
    21 8.23
    22 8.22
    23 8.25
    24 8.25
    25 8.24
    26 8.24
    27 8.26
    28 8.20
    Would I be correct to assume pack 11 needs to be replaced ?
    I can pick up a second hand one relatively cheap in ireland
    49,473
    welcome!
    looks like it, but a load test might show others as well.
  3. Bazzy
    Bazzy New Member
    Ireland
    I'm new enough to this how would i perform a load test?
  4. bisco
    49,473
    you can buy a tool from hybrid automotive, or if you want to delve into the pack, there are threads here detailing how to rebuild a battery properly, and using a light bulb to load test, and hobby charger to recharge.
  5. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    Here's one way to do it.
    HA Load test.
    Enjoy.
