After my Combination Meter repair this is what happened
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chrizoroer, Apr 7, 2019.
  1. Chrizoroer
    Chrizoroer New Member
    TX
    Hey Folks,
    I had the repair done by a guy from ebay. Got the board back today put everything back in BUT the car isn't working. Pretty much ALL the dash lights are on. When I scanned for the error codes I got back the following:
    Trouble Code:
    C0300
    Permanent DTC:
    C3F0A
    P117F
    P0A11
    C3F0A
    Pending DTC:
    C0700
    I must be searching in the wrong parst of the internet because I can't find good explanations for the C-Error codes.
    Please help. In the meantime I'll take the prius apart again and double check all connections.
    Thank for your help in advance,
    Chriz
  2. Chrizoroer
    TX
    Well... Problem solved!
    I was just about to take apart the car again I realized that the orange battery disconnect on the traction battery wasn't locked all the way. I locked it fired up the car and lo and behold it starts and has no error codes whatsoever.
    Simple as that! :D
    GrayRaceCat, Mendel Leisk and bisco like this.
  3. bisco
    49,375
    what are you reading the codes with? sounds like another faulty combo meter or connection
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    I would not have guessed that! No reason to pull that orange safety disconnect. When the car is off, the traction battery is disconnected from the car by a relay. And there are no high voltage cables or connections around the area. But I would definitely disconnect the 12V battery to help prevent the air bags from exploding in my face.
    Anyway, glad you got it fixed with no big adventures. :)
  5. bisco
    49,375
    never mind:oops:
  6. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    Am I wrong in assuming that Toyota fixed the problem with the combo meters by 2008? Reason I ask, I am working on a 2009 and While driving around and stopping, etc. then restarting, the combo meter went black... The car will run but the display is black. Do I need to replace the capacitor in the combo meter now?
  7. jerrymildred
    11,508
    14,109
    Tampa, FL
    I don't remember ever reading anywhere that they fixed it. And I think I've read of it happening in the later Gen 2s, but it would be less common since they aren't as old. It sounds like you've got a classic case.
    GrayRaceCat likes this.
  8. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    I have an extra capacitor ( 220 micro farrad that i replaced the original 100 microfarrad capacitor with) and all is working fine. It is a known issue and the fix is pretty easy... about an hour.
  9. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Why did you pull the hybrid battery safety interlock?
  11. jerrymildred
    11,508
    14,109
    Tampa, FL
    Are you mixing up the current conversation with papawill with the one back in April with chrizoroer?
  12. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Not mixing up anything responding to the OP's post.
    Which is becoming increasing difficult based on how many people hijack threads on this site.
    Skibob and jerrymildred like this.
  13. jerrymildred
    11,508
    14,109
    Tampa, FL
    Understood. (y) The question is a good one and got asked back in April and never answered.
