2007 Prius: no power at all (2 month new 12 v battery)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ceegee, Sep 2, 2018.
  1. ceegee
    ceegee Junior Member
    Attempted to start the car today...there was no power at all. No lights, dash is black, door locks don't work, nothing. I had a new Toyota battery installed a couple of months ago and the car has been running fine.
    I haven't been in the car in a couple of days so I can't say for certain that something hasn't drained the battery, but even a drained battery usually shows some signs of life doesn't it? The only light that registered was when I put the key in the ignition and the power button showed orange then red.
    It's Labor Day weekend so it's going to be difficult to get service until after the holiday, but I'm wondering if I should attempt to have the battery jump started. The alternative would be to wait until after the holiday, and if it can't be jumpstarted, Geico road service could then tow it to my mechanic.
    Can anyone offer any recommendations for me on this problem?
    Thanks!
    52,351
    i would try to jump start. if it starts, you can leave it in ready for 8 hours to charge up the 12 volt, or drive around for a few hours.
    even then, it may be irreversibly damaged. it should be under warranty.
    if it doesn't start, you're going to have to get a volt meter to find out if it is the 12v or something else.
    check the battery connections, and negative to ground.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Use a voltmeter to see what voltage the battery is at. If low, them jump start it. Or buy a 12v charger to charge it back up.
  4. ceegee
    Bisco, thanks for the reply. I'm going to call roadside service tomorrow and see if they can jump start it. Seems odd that the battery would be completely dead after 2 months...I mean I've had to jump start the battery after I accidentally let it drain before (by leaving the map light on) and it never discharged so completely in just 2 days that there was NO power at all. Anyway, my fingers are crossed. If I get it started, I'll take it back to the mechanic who installed the battery and have him test it. I appreciate the advice.
  5. ceegee
    Ericbecky, I don't actually have a volt meter, plus wouldn't I need access to the 12 volt battery in the trunk (door unlock is not working)?
  6. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    You can access the jump points under the hood to measure voltage.
    Or access the battery after opening the hatch by crawling into the back area and accessible the hidden manual switch.
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Pick up a trickle charger and trickle charge it for a few days, even if someone jump starts it, the system never really tops off the 12v battery, it needs monthly top off's, the age indicates a new traction battery in your future, get a toyota new factory installed sucker.
  8. Greg K
    Greg K New Member
    New Jersey
    I just had the dead car problem on a 2004 Prius. After changing the inverter cooling pump, I started the car and the check engine light was still on so I decided to disconnect the ground wire from the 12v battery to reset the fault. Upon reconnecting the negative battery cable, the car was completely dead. No lights, no response to the key fob. After disconnecting and reconnecting the negative cable on the battery a few times with mixed success, I discovered that the positive battery cable was loose on the battery post. So, if the car is totally dead, check tightness of both battery cables,, not just the negative. I believe that every time I opened or closed a door, or the hatch, the movement could make or break the connection of the loose cable. I'm not impressed with the positive battery connection design. The battery post should be larger, or the clamp on it should be smaller to tightened better.
  9. Henry1234567890
    Henry1234567890 New Member
    Oregon
    What was the issue? I have the same problem! No power at all! Could it be a loose connection? I hope so! Battery is still at 12V I check with a multimeter but zero power at all! Help please!
  10. Henry1234567890
    Oregon
    And the connector ports do have power also have 12V power meaning that the power is indeed going through the connectors. Works perfectly when jumpstarted only. And once I push the off button, it goes completely dead no light or sounds at all!
  11. Henry1234567890
    Oregon
    I have a different voltage at the rear battery (12V) and at the front terminal is 1.7V when the car is off
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Simple to measure the battery. Just measure the front jump point to ground.
    Does not matter what the battery itself measures in the trunk it only matters what is getting to the front fuse box via the jump bolt in the front fuse box. The jump bolt is bolting down the main power cable from the battery.
    I go for years not looking at the battery in the trunk. Everything I need is on that jump bolt. That’s where I do routine battery charges.
  13. edthefox5
    10,096
    4,834
    Clearwater, Florida
    1.7 volts is stone dead. If you have 12 volts in the rear at the battery
    And no volts at the front that means the 100 amp fuse that’s in the black plastic assy boltedto the positive jump point on top of the battery.
    That sometimes blows if you reverse polarity jumped it which happens a lot if your jumping the battery in the trunk.
    And sometimes ifthat fuse is blown the inverter gets damaged too.
    Whatever happens never jump start a g2 Prius. We have seen so many of them damaged by that. Big $$$$$$$.
  14. Henry1234567890
    Oregon
    I bought used and in a rough condition. Not sure if the previous owner did. But 100% I did not reverse polarity while jumpstarting this car. I check all the connections going to the two connectors (that attach to the black plastic assembly on top of the battery) and there are 12V at the connections. So they are good. Connectors and cables look good too. But yeah that’s so weird! I just drove 40 miles no issues whatsoever. When I jumpstart it. I hear clicking multiple times and then boom turns on! Sounds like a relay clicking but I don’t know what relay does that? Could it be the fusible link? I inspected both and look perfectly fine. Or may be the front one is damaged. I am not sure how to check that one but the rear one is definitely intact and working. The weird thing is that once. I mean ONCE, I moved around the positive connection and the car turned on. And as soon I turned it off it went dead again. I didn’t move anything. I was just removing the red cover on the positive terminal. But it never worked again. It only happened once, it tightened the connections and clean the contacts and there are 12V going through so it has good connections. I am
    Not sure what wrong, any leads from this information? Please
  15. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Ok you have bad connections on that battery. Take the positive post assy off and using sandpaper sand the patina off the positive post. Do the same to the negative post. Remove the bolt that holds the negative cable to the back body wall. Sand down the area where the negative cable meets the body. Apply grease to that area and bolt the negative cable back on. Apply grease to the battery posts and bolt them back on.
    After bolting it back up measure the battery voltage at the front jump point. Measure with the car off. Write that down. Then with the car off turn on the headlights turn on the high beams and let the headlights run for exactly 5 mins. Then with car still off shut the headlights off and wait one minute and ,then measure the front jump point.
    Whats the dc measure then? I bet less than 11 volts.
    Btw the relay clicking is the main power relay inside the hybrid battery box that connects the battery to the car.
