How to reset oil maintenance data ? (Manual instructions did not work.)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Happy35234, Jul 17, 2019.
  1. Happy35234
    Happy35234 New Member
    CANADA
    Prius 2013. From manual pg. 409
    But these steps did not reset oil maintenance data. Help!
  2. Happy35234
    CANADA
    #2 Happy35234, Jul 17, 2019
  3. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Step 3, replace the word “pressing” with “holding down.”
    #3 Grit, Jul 17, 2019
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Gen 3 is totally different from Gen 2. @Grit has the solution.
    The manual is stupidly worded. "Keep pressing" can sound like it should mean, "press repeatedly." But it actually means "hold down."
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    This procedure just worked (as always has) on my 2014. Hold down the MPH/KM button while pressing the Power button. Keep holding the MPH/KM button down while the Progress Indicator completes. You can release the Power button as soon as the Progress Indicator appears, while still holding the MPH/KM button down.
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,157
    Tampa, FL
    Exactly. There's no mention of "pressing" the power button; it just says to turn the power switch to "ON." (Which, of course, is done by pressing it, but not holding it.) (y)
  7. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    Other tips not clear in the manual:
    With car in READY state, shut down as usual, after making sure trip A is showing,
    With brake pedal NOT pressed, hold down the km-mile button, then press and release power button two times, while still holding km-mile button. Keep holding until display confirms you succeeded.
    Happy35234 likes this.
  8. Da1sy
    Da1sy Junior Member
    Wisconsin
    I have followed all of these steps and I still cannot clear the Maintenance required light. Yesterday the dealership that changed the oil told me they had tried to clear it also with no luck. Any ideas?
  9. jerrymildred
    11,517
    14,157
    Tampa, FL
    There's no excuse for the dealer not being able to do this. WOW! However, this is a question on the Gen 3 reset. Your Gen 2 is different. Here's how I reset it on my wife's '07. (page 131 in the manual)
    WilDavis likes this.
  10. 8AAGen2
    8AAGen2 New Member
    29
    Maryland
    I
    Sorry for not offering my experience sooner, but I just ran across this thread. I have a GenII and one time I had the oil changed and the technician told me that he couldn't reset the maintenance light. It wasn't the first time that had happened, and figured that he just didn't know how. I tried to reset it using the normal method of holding down the MPH/KM button while starting the car, but it didn't work this time. I tried it again with the same result. I was able to clear it by going into the maintenance menu on the Multi-Purpose Display and clearing it there. I don't understand why the normal shortcut didn't. Subsequent to that the shortcut method worked fine again.
