Speedometer - mph / kph
Discussion in 'Prime Main Forum (2017-2022)' started by dave121, Sep 11, 2019.
  1. dave121
    dave121 Junior Member
    Maryland
    2018 Prius Prime
    Is there a way to change the speedometer from miles per hour to kilometers per hour? I could only find the answer for older models of the Prius, and holding the trip button in odometer screen didn't seem to work for my 2018 Prime.
    Thanks - Dave
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    It’s on the MID (multi-information display), using the right-hand steering-wheel controls. In the “settings” part, one of the right-most menus:
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    It should be just like the other Gen 4s. Use the scroll button on the right side of your steering wheel to change the MID to the settings functions (icon like a gear) and the scroll down to the kp/h MPH function and toggle it. If your manual is like my 2017, it's in the "Settings" section.
    Edit to add: You beat me to it while I typed, @mr88cet! (y)
    Prius from Dad likes this.
  4. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    a simple 'RTFM' would suffice.
  5. jerrymildred
    11,517
    14,157
    Tampa, FL
    To run people off.
    I'm often tempted, but usually control myself.
    Edit to add: That said, with this car, the manual is your best friend. Spend some quality time with it and you'll like your car even more.
    #5 jerrymildred, Sep 11, 2019
    ziggy29 and pghyndman like this.
  6. Mendel Leisk
    41,826
    Just trolling, but anyway, third gen:
    mrwhsprs and jerrymildred like this.
  7. jerrymildred
    11,517
    14,157
    Tampa, FL
  8. dave121
    Maryland
    2018 Prius Prime
    Never got a change to reply, but thanks for posting the info...was helpful for driving around Quebec. MPH signs end shortly after border, and doing the conversion in my head got old quick, especially when trying to navigate at the same time.
    Thank You!
  9. dave121
    Maryland
    2018 Prius Prime
    Thanks!
    jerrymildred likes this.
