Brake Clean safe on RAGS to clean intake tracks on cylinder head?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pingd, Sep 30, 2019.
  1. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    153k miles and doing the whole EGR circuit cleaning. (languishing at EGR cooler removal ... uggghhhh)
    I have the intake manifold (IM) completely off. (have a spare, clean, used one from ebay $120)
    I'm trying to clean the "intake tracks on the cylinder head" (i.e. where the IM mates with the engine)(is there a better name?)[reference: NAB video "Intake manifold cleaning" at 23:20]
    I know NOT to spray cleaner in.
    Is it safe to use brake cleaner sparingly on a cloth rag to wipe it down though?
    I also know NOT to clean the fuel injectors at the back. If the cleaning cloth brushes against it ... that's ok right? (i.e. they're not that delicate are they?)
    Thank you!
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Yes, it is safe to use brake cleaner or carb cleaner on a cloth to wipe down the cylinder head intake ports.
    Dont worry about brushing against the fuel injectors, the fuel injectors are not overly delicate.
    I found the EGR cooler took far longer to clean compared to the intake manifold (a spare EGR cooler off eBay would be preferred over intake manifold)
    #2 IMkenNY, Sep 30, 2019
  3. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Thanks much Ken ... will proceed as advised on the cylinder head intake ports (knew there was a better name!).
    I did also order a new EGR cooler 25601-37010 from ebay seller triplecreations $142+30=$172 (fast ship from Dubai/UAE, was skeptical but appears 100% genuine).
    Just having so much trouble with access to the back of the EGR cooler and rusted bolts ... trying to Kroil it now.
    #3 pingd, Sep 30, 2019
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    The back nuts aren’t easy :cool:.
    Once you get the lower one off, be ready to catch the gasket;).
