What have I gotten myself into?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BuckeyePrius, Oct 3, 2019.
  1. BuckeyePrius
    BuckeyePrius Junior Member
    Recently acquired:
    2007 with 290xxx miles
    Codes 1116 and 1121
    Engine idles rough has loudish ticking/tapping noise
    Runs poorly, appears to be running the ICE constantly
    HV / Traction battery will not charge
    Traction battery was replaced by Toyota in 2015
    New 12volt battery May of 2019
    VSC Brake light etc... lit up on dash...
    Combination Meter Display non working /reset by disconnecting 12v
    One odd size tire on the rear
    Previous owner replaced one rear hub assembly
    Has a partial bottle of pink extra life antifreeze in hatch area
    Appears someone has been "working" on the vehicle
    Where to begin?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    See a shrink about your masochistic tendencies ??
    (Mostly not a joke.)
    If the traction battery is bad AND the engine has worn out bearings and maybe a leaking head gasket.......I would consider it worth LESS than nothing. Might get a little out of parting it out.
    BuckeyePrius likes this.
  4. BuckeyePrius
    Was a cheap scanner, I am waiting on a new ELM? and will be using the Dr Prius app to recheck the codes.
  5. bisco
    52,433
    replace the odd size tire with an even one.
    all the best!(y)
    donbright and BuckeyePrius like this.
  6. BuckeyePrius
    I think it may be a disease, we have two other 2007's and a 2005 as well. Have had various issues with each one but this is by far the most challenging.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    I'm not afraid of miles.
    Codes 1116 and 1121
    Codes P1116 and 1121 ae no big deal and are heat storage related. 16 is temperature sensor and 21 is flow control valve. I think both can be triggered if the computer thinks the system performance is weak due to clogging. Throw in half a gallon of coolant and makes you wonder if previous owner was working on it.
    And of course, that half gallon of coolant could have an even more evil background based on your description of how the engine is running. There could be engine related problems like a head gasket. But I've also had horrible ticking noises come from a misfire. You'll know more when you get techstream. You are going to do that right?
    If the HV battery was truly replaced by Toyota in 20015, with a factory new battery, odds are slim you have a battery problem. Slim, but not zero. The electronics section of the battery would still be original 2007 equipment, which means there may be corrosion issues in the ecu harness plug. These issues will become crystal clear when you get techstream.
    Sweet. Make sure it's fully charged so you're not chasing your tail.
    Hate that and hate what it possibly means. Did I mention that will become more clear with techstream?
    Combo meter....nbd, seems to be a fairly common occurrence at that age. As long as it continues to only be an intermittent problem, you can fix it when convenient.
    Yikes. Obviously something that should be rectified prior to making it a driver, but should have no impact while parked in driveway while performing repairs.
    Good for him, and you, as long as he didn't tear anything up.
    Makes you wonder what the other half gallon was used for. What system needed it …..
    Did I mention this is like the perfect time to have Techstream...there are no third party apps that can even come close. It's like the difference between having a neighbor look at you and give you a medical diagnosis or going to a specialist and having a full body MRI performed.
    Raytheeagle and SFO like this.
  8. BuckeyePrius
    With the number of Prii we have, this makes #4 I really should look into the techstream. Thanks for the feedback.
  9. BuckeyePrius
    LZLRUN Mini Vci Interface for Toyota J2354 Tis Techstream Diagnostic Cable Toyota Firmware V1.4.1
    Is this what I should be looking for?
    If not please point me in the right direction. Thanks
