Where is the yaw rate sensor located in the 2008 Prius?
Discussion in 'Gen 3 Prius Audio and Electronics' started by MC's 08 Prius, Feb 7, 2015.
  1. MC's 08 Prius
    MC's 08 Prius New Member
    I bought a used 2008 Prius that had a VSC light on. I went to my mechanic who scanned it and said that the yaw sensor wasn't functioning. He wasn't too familiar with Prius's and said he'd need to look into this further. I was wondering if this is something that can just be changed out and reset with an OBD2 scanner. Any insight would be greatly appreciated.
  2. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    You can find it under the center console. I'ts probably out of calibration and can be re calibrated with the proper scan tool.
    Avi
  3. Panday
    Panday New Member
    Ca
    Does anyone know where the yaw sensor is
  4. SADIK
    SADIK New Member
    Blackburn
    ----UK----
    Hi can anyone thell me location for yaw sensor Toyota prius 2006/06 plate
  5. RRxing
    RRxing Senior Member
    2,557
    1,831
    NEPA
    As mentioned, it's typically under the center console.
  6. tre4xw30
    tre4xw30 Junior Member
    37
    US
    Its under the center console on a gen3
    SM-N950U1 ?
