Engine Compatibility 2013 Gen 3
Discussion in 'Gen 3 Prius Main Forum' started by donzoh1, Oct 8, 2019.
  1. donzoh1
    donzoh1 Active Member
    448
    153
    Lenexa, KS
    I have a Gen 3 Prius I'm trying to get running again. It needs a new engine block at minimum, and I'm thinking of a junkyard engine to replace the factory motor, hopefully without creating computer problems or other compatibility issues.
    But, I can't find a donor Prius near Kansas City. Does anyone know which car years and models would work without too much trouble. I know there was a Lexus, a Corolla (maybe hybrid). Would the 1.8 from a Corolla work in general?
    51,837
    2010-15 liftback, and i think there's a thread here where someone stuffed a gen 4 in. did you try LKQ?
  3. bettergolf
    bettergolf Active Member
    487
    366
    Sanford NC
    car-part.com....national "used auto parts" website...I see lots of Prius engines including a 2015 with 86k miles for $1250 that is in Springfield.
  4. Mendel Leisk
    41,301
    Yeah, quite a saga:
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    The thread's pinned in sort of an odd location; it's a Prius v he's doing the 4th gen transplant into, but it it is the same process for 3rd gen Prius.
    Note too, there's someone else who did the same transplant, but managed even more complete, transferred the complete 4th gen EGR system over as well. The major mod he needed to do was heat up and bend the (3rd gen) exhaust manifold pipe that connects to the EGR cooler, to make the connection. I believe he contributed to the above thread?
  5. donzoh1
    448
    153
    Lenexa, KS
    I did look at LKQ but those are about the same as complete rebuilds from ebay.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
