Brake buzzer noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Matthew J Anderson, Oct 9, 2019.
  1. Matthew J Anderson
    Matthew J Anderson Junior Member
    Winnsboro, SC
    I am getting the annoying buzzer noise when pressing the brake pedal twice almost every time. What could this be? It buzzes for like few seconds. Very annoying. I have a Toyota Prius three 2012
  2. Matthew J Anderson
    Winnsboro, SC
  3. bisco
    51,640
    isn't it the accumulator filling?
    what do you mean by 'pressing the brake twice'?
  4. bisco
    51,640
    it's normal. the pedal activates the accumulator pump
  5. Matthew J Anderson
    Winnsboro, SC
    It does it EVERY time I press the brake pedal towards the floor or put pressure on the brake pedal at least twice then it buzzes it’s SO annoying and audible through The Whole car! For example I press it once, then I press it again and there it goes “BZZZZZZz” every single time are you sure that’s normal?
  6. Mendel Leisk
    41,083
    If the buzzing is happening real frequently, might be something failing?
  7. bisco
    51,640
    hard to say, you're making it sound louder than normal. has it changed?
    can you post a recording?
  8. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Mine used to do that but somehow doesn’t do it anymore due to me not pressing down the brake too hard
  9. bisco
    51,640
    perhaps some freshening of the brake fluid?
  10. Matthew J Anderson
    Winnsboro, SC
    How can I post a recording on here
  11. Matthew J Anderson
    Winnsboro, SC
    I posted it on YouTube hopefully you guys can hear it
  12. Matthew J Anderson
    Winnsboro, SC
    Basically every two pumps of the brake pedal there is an annoying buzzer noise
  13. Matthew J Anderson
    Winnsboro, SC
    It even buzzed while holding the pedal open and pumping it toward the floor smh
  14. Mendel Leisk
    41,083
    Again, that seems too frequent. I vaguely recall that was a sign of something failing. Get a dealership mechanic to test drive? There is a warranty extension on the brake bits mounted on the firewall.
  15. bisco
    51,640
    could be a faulty actuator. go on toyotaowners.com and see if you qualify for the extended warranty
  16. bisco
    51,640
    what happens if you just press the pedal and hold, like normal braking?
