CV Axle will NOT come out.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Oct 9, 2019.
  1. Prius92
    Prius92 Member
    376
    95
    Iowa
    I accidentally posted this in the wrong forum originally.
    Anyway, the driver's side CV axle needed replaced as it was groaning loudly on turns and clunking on light acceleration and braking.
    Go to remove it..and notice the nut has been unstaked, meaning someone either tried to remove it before, or replaced the wheel bearing and didn't restake the nut.
    Get the hub and all that pulled away, axle will NOT budge. It will slide in and out easily, but stops once it hits the circlip. Tried a removal tool, small pry bar, very long pry bar, and nothing would pop it free. Didn't put any more pressure on it in fear of damaging the transaxle case. I think I already ripped the oil seal on it.
    It really irritates me, I've worked on cars since I was a young teen and never before have I not been able to fix something. I had to call AAA and have it towed to a shop.
    I'm wondering if maybe the axle had so much slop (you could push it in and out a little bit) if over time it hammered on that circlip and flattened it out.
    I'm already broke as it is, and luckily got a brand new (not rebuilt) axle for $50. If they have to get into the transaxle to remove that axle, I might as well kiss my next paycheck goodbye.
  2. Frijjj
    Frijjj Member
    60
    35
    Runcorn, UK
    Sounds horrendous. Hopefully the shop can fix it without too much cost
    donbright likes this.
  3. Frontporch
    Frontporch Member
    398
    82
    Nj
    I had to pull the axles to replace my transmission a few years ago. I remember there being very little to pry on and was very difficult to pry evenly to release the circlip. I don't remember much sliding of the end of the axle before that clip released, but I could be mistaken.
    I like to get better leverage when I do stuff like this. One trick that has worked for me in the past is to put a reasonable quality hose clamp around the fat part of the axle by the transmission and make it good and tight. The screw part of the hose clamp makes a pretty darn good place to pry without messing with the ends of the axle. Better yet, use two hose clamps and you can position them 180 degrees apart to a good place to evenly pop out the axle. Be prepared to waste a clamp or two, but they should be cheap.
    The axle seal wasn't bad to remove or replace. Only catch I found was they specified it had to be pressed in just beyond the edge of the axle casing. I got past that with an ABS plumbing connector from the home center and a washer made from copper wire.
    All that said, your description of the axle moving freely but getting stuck seems odd to me. From what I recall, there was very little play at the end of the axle. More if you grab the shaft I think, but that's because of normal play in a CV joint
    edthefox5 likes this.
  4. Frontporch
    Frontporch Member
    398
    82
    Nj
    Just to be clear, I put the hose clamp around the black (non-rubber) part of the axle shown above. There are some ridges that can attempt to use, but they are so shallow that they are worthless. Probably made for a Toyota shop tool.
    I don't think you should be able to see any of the shiny silver or brass parts of the axle shaft inside the transmission until that circlip has released. You also shouldn't be able to get at the oil seal in the transmission until the circlip has released. I don't think you really damage that seal until you take out the axle and somehow get part of the splined shaft to pull on the seal. I replaced mine because the scrap yard jammed plugs into the seal after they removed the transmission.
  5. Classic_pri
    Classic_pri Former 2001 Prius 0wner
    108
    27
    Wisconsin
    Yes, it can be very hard to apply pressure evenly to pry that inner CV joint out of the trans. Plus, you're usually lying on your back or belly with arms extended so you can't optimize the force you apply. Once force is applied evenly, the joint pops out and you wonder how it possibly could have been so hard.
    There are a number of Youtube videos of techniques to pull a stubborn axle. One guy uses an OTC slide hammer with CV removal tool from Autozone. Another builds a similar tool from bar stock and an electrical junction box he has cut into a C shape. A third uses a length of chain and a slide hammer. The consistent theme seems to be to get out from under the car into a position where you can deliver force evenly. Also, impact force (from a slide hammer, say) is easier to apply evenly than prying force.
  6. Prius92
    Prius92 Member
    376
    95
    Iowa
    Well the shop was able to replace the axle, they said they had it out in 20 minutes. I guess having the correct puller helps a lot.
    But rather annoyed, took the center cover off the wheel and the nut isn't staked (round edge punched into indentation).
    Should I stake the nut, or does it not need it?
  7. Frontporch
    Frontporch Member
    398
    82
    Nj
    I would stake it and not give it much thought. I personally think it coming loose is unlikely but it takes a few minutes and I assume you have the tools
