Tip: Re-sealing Fuel Pump Access Cover
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Oct 10, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    If you ever need to replace the fuel pump on your Gen3, you will need to re-seal the access cover. The access cover is sealed to the body using butyl tape and it will no longer attach securely once it is removed. Initially I thought a new cover would include the tape, but of course it did not.
    3M #08578 is what you will need. I purchased mine from JBTools for $18 and now I have way too much leftover.
    iPhone ? Pro
    Elektroingenieur, m.wynn, RMB and 4 others like this.
  2. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Good looking out. This is the same stuff used to re-seal headlight lamps I believe.
    RMB, Raytheeagle and The Critic like this.
  3. Mendel Leisk
    41,911
    Is there something special about the 3M tape, say impervious to gas? If I google butyl tape I get lots of hardware store results, tape and caulking tubes. Also used for eave troughs and that sort of thing?
    Googling the 3M tape specifically, it does have a lot of automotive applications indicated.
    3M™ Strip Caulk, 08578, black, 1 ft. (.30 m)
  4. The Critic
    3,193
    2,333
    CA
    I am not sure. It is merely an access cover that needs to seal against the outside elements. I think any butyl tape should work.
    iPhone ? Pro
    #4 The Critic, Oct 11, 2019
  5. Mendel Leisk
    41,911
    Gas doesn't slosh up there then? Maybe just fumes if it wasn't sealed?
  6. Elektroingenieur
    2,515
    3,287
    Three Touring
    The access cover isn’t part of the fuel tank itself. Butyl rubber isn’t resistant to gasoline (or other liquid petroleum compounds), but here, the seal just needs to keep out moisture and, potentially, fuel vapors or exhaust gases, and not to harden or crack with age.
    I agree; as discussed before, Toyota sells as tape kit in Japan, but it’s not available from U.S. dealers.
    Did you use the Toyota special service tool (09808-14030, now 09808-14031) to remove and reinstall the fuel pump gauge retainer? If not, can you suggest a good alternative for the do-it-yourself mechanic?
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,501
    Taylors, SC
    Even less expensive and serves the same purpose is plumber's putty.
  8. Georgina Rudkus
    3,513
    2,501
    Taylors, SC
  9. Mendel Leisk
    41,911
    Does the sealant need to be "tacky"? I don't think plumbers putty would fit the bill; it needs mechanical connection of parts.
