Wheel cover for Prime
Discussion in 'Prime Main Forum (2017-2022)' started by Hokiehigh, Oct 12, 2019.
  1. Hokiehigh
    Hokiehigh Junior Member
    CT
    2018 Prius Prime
    AHh.. lost a wheel cover last week. I thought the wheel covers were ugly. Guess what, w/o the cover, the wheel is uglier.. at least to me.
    New cover costs $80 at the dealer, I would not pay that much for a plastic piece that might get knocked off again. I figure some of the members here have upgraded their wheels, may have the original set lying around. I wouldn't mind buying a whole wheel as spare, or just the cover.
    Please let me know if you have one for sale. Thx
  2. NSXT
    NSXT Active Member
    137
    119
    Toronto, Canada
    2018 Prius Prime
  3. Hokiehigh
    CT
    2018 Prius Prime
    I might go with this route, $$85 a piece is ridiculous for what it is. I can sell the three covers I have for at lease $100 :)
  4. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    I scrapped and bent my wheel cover for my prime. Where would you guys recommend purchasing one and how much should it be around? I saw in the thread that it is around $65? I know you guys mentioned just taking them off but I would like to replace this cover. Thanks guys
  5. Washingtonian
    Washingtonian Senior Member
    726
    621
    I removed mine in the first month I had the car because I think the wheels look much better without the wheel covers. I am keeping mine because when I sell the car some time in the future there is a good chance that one or more of the wheels will have been curbed or scratched up. Pop on the wheel covers and they will look like new again.
  6. DavidA
    2,344
    1,820
    Chicago western burbs
    Mine were never on the car. I instructed the salesperson to walk the prep team to keep them in the plastic bags and place them in the back. When I picked up the car, I walked around it popping in the center wheel caps with my fist. Salesperson, possibly, was amused.
    Also, with the wheel covers off, you can check air pressure and fill if needed. Yup, stupidly, the covers also cover the valve stem.
    benagi likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I have the covers still on our wheels and I can check the tire pressure and fill up the tires when needed;).
    Since there is a cut out for the valve stem, aligning that with the valve stem ensures you can do the same thing(y).
  8. Mendel Leisk
    41,350
    Yeah the wheel covers have a cut-out that allows valve access. OTOH, I think it's a little more finicky, and you can drop the cap, and they invariably will fall into the rim, leading to #*@!$ good times. :)
    @JImmyPriNew even made a video, a little funnel gizmo to divert the cap from falling in. Can't find it on his YouTube channel, guess it was just an informal DIY video. His YouTube is worth a visit; the guy is kinda like Bob Roth.
    Wonderful Wandering Topics - YouTube
    #8 Mendel Leisk, Oct 14, 2019
    vvillovv and Raytheeagle like this.
  9. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    I find it much easier to check tire pressure with the wheel covers removed.
  10. NSXT
    NSXT Active Member
    137
    119
    Toronto, Canada
    2018 Prius Prime
  11. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
  12. DavidA
    2,344
    1,820
    OK, I've learned something today! Thanks! Yet, the covers stay off my car.
  13. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Mine has an external TPMS sensor (valve cap) on the stem that kinda matches the OEM wheel cap. :D
    No need to check the air pressure.
  14. DavidA
    2,344
    1,820
    Can you tell what the actual tire pressure is? Or only if it is too low?
  15. benagi
    benagi Active Member
    525
    280
    Utah
    If it is like the TPMS on my motorhome, you can read the current air pressure for each tire on my display on the dash.
  16. Salamander_King
    11,016
    8,948
    New England
    Yap, the kit is a cheap ~$30 TPMS with a solar monitor unit that sits on the dash that tells each tire pressure real-time. I have checked the tire pressure using 4 different gauges and compared the value to this TPMS as well as an internal reading by TOYOTA OEM, and found they are very close to each other.
