False alarm!
Discussion in 'Prime Main Forum (2017-2022)' started by mveras1972, Oct 11, 2019.
  1. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Many times when making a sharp left turn, my 2017 Prime thinks I’m going to hit something. The first time I heard the warning beeps, it scared me and looked around and there was nothing I was about to hit. I’m now used to it and I just ignore it, not a good thing. It doesn’t happen every time I turn left but I would say I get those false alarms about 50% of the times I take a left turn at an intersection. And it’s only on left turns, especially sharp lefts. Never happens on right turns. Anyone had this happen?
    iPad ?
    #1 mveras1972, Oct 11, 2019
  2. DavidA
    2,325
    1,811
    Chicago western burbs
    No, not while driving or turning. The software for all the sensors was upgraded last year with a service bulletin notice for my model year. It is now WAY more sensitive than ever before, with a new sensor location-based readout on the MID screen. By way more sensitive I mean this... where I park at work there is a small branch of a bush with not very many leaves on it that is behind the curb. The car goes crazy when it sees that tiny branch as I am parking at 0.05 miles per hour. Yet, at one spot over, with no branch, it pretty much can't see the relatively tall curb I'm about to hit at all. Improper aiming, maybe, maybe not.
    So while it may be more sensitive, and all models past 2017 are, it still isn't trustworthy.
    mveras1972 likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Just one time. It was a sharp left curve on a rural road with a huge metal high tension line pole positioned to where, if (when) a car misses the curve, it will take down the pole, kill the car's occupants, and shut off power for thousands of people. The car didn't do a panic stop, but it sure startled me with its warning
  4. Tideland Prius
    16,070
    Yup. Because it detects a passing car (oncoming) before I turn left. Happens both on the street and in parking lots.
    jerrymildred likes this.
  5. Mendel Leisk
    38,234
    Sounds like a good place for some bollards or crash absorbers of some kind.
  6. huskers
    huskers Senior Member
    2,542
    2,486
    Nebraska
    Did you remove the branch?
  7. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    If there was an oncoming car, I wouldn't be turning left. I've had this happen when there's no traffic at all in any direction.
  8. Tideland Prius
    16,070
    This is after the car has passed. The Prime retains memory (about 2 mins IIRC) from its side sensors in case there are pillars or parked cars beside you and you turn too sharply.
    It shouldn’t occur if there’s no one around you at all. But if someone passed by recently (e.g. oncoming traffic) or you passed something closely, it will remember it.
  9. DavidA
    2,325
    1,811
    I have tried to remember to bring a cutter with me to work. I would rather remove the more dangerous curb, but that would be blatant vandalism.
    But the reality of parking next to plant life is that the wind could blow branches against a car and cause scratches. I've got a good long one on my hood due to that.
