Tire Size & Winter Tires
Discussion in 'Prius c Main Forum' started by unsunder, Oct 10, 2019.
  1. unsunder
    unsunder New Member
    Colorado
    We moved to Southern Colorado this summer and the first snowfall has me shopping for snow tires.
    I'm wondering if it's okay to swap in 185/65/15 mounted on 15x5.5 rims. Someone has a set of 4 locally off of a Honda Fit. Will they fit and or is that a bad/good idea if they do?
  2. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    185/65R15 is 2% smaller than the stock 195/65R15 tire. That is the practical limit for variation. So, it’ll work, but you’ll see 2% worth of error on your speedo/odo. Also this will impact your fuel mileage slightly but again, won’t be much.
    EDIT: I remembered the stock size incorrectly, see below
    CORRECTION: With 185/65R15 in place of 175/65R15 the snow tires will be 2.1% oversized. Slightly larger error in the opposite direction. 2% is commonly cited as the largest variation you’d want, so that makes these an iffy call.
    Snow tires are very much worth it, they help a lot. We use a slightly undersized set on our car.
    Good luck!
    #2 Leadfoot J. McCoalroller, Oct 11, 2019
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    I have read narrower and taller sidewall snow tires are better on deep snow and I can see the reasoning behind it, but do they help on plowed snow or on ice?
  4. unsunder
    unsunder New Member
    Colorado
    Thanks for the reply. The Prius C are stocked with 175/65 15's
  5. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Ah sorry, I think my prior post was poorly worded.
    I meant to indicate that having snow tires helps a lot. I’m not trying to characterize the sizing as an improvement. That said, I’ve found narrow/high profile to work well in situations where there’s better traction under the surface. Wet Eastern states with salted roads generally qualify.
  6. unsunder
    unsunder New Member
    Colorado
    I decided to pass on the used set and purchased the stock size winter tire as well as aftermarket steel wheels. Paid $425 + the cost to mount/balance. Not too bad considering the safety of my wife and her 70 mile a day commute through a mountain pass.
  7. Mendel Leisk
    41,915
    The stock Prius c tire size is 175/65R15?
    Still not matching size, anyway.
    Hub opening, lug nut seat style, lug nut bolt-circle, offset, brake clearance, and so on: I'd guess they wouldn't work.
  8. Salamander_King
    11,024
    8,970
    New England
    Aha! That I agree 100%. I have always picked the same OEM size snow tires for my daily drives. I never picked smaller snow tires, that is until this year. I had to buy a set of snow tires for our Pathfinder that came with 20 inch low profile tires and wheel. Trying to find snow tire for that size was difficult enough but if I wanted to buy a set of wheels of that size, the cost becomes prohibitive. That's when I realized that the car came with smaller OEM wheels and tires on lower trim models. I was able to source cheap used wheels in that smaller size and I just ordered a set of 18 inch snow tires to fit on them. But I was just curious if the smaller snow tires would help on plowed and icy roads compared to larger 20 inch tires if they are the same model of snow tires.
    #8 Salamander_King, Oct 11, 2019
  9. Salamander_King
    11,024
    8,970
    New England
    Just checked for 2017 Prius C and 2017 Fit OEM wheel spec. Your Prius C year and what you found on Fit may be different, but they do have the same bolt pattern. If the wheel that comes with the snow has 15x5.5 rims, that may not be OEM. At least Fit's center bore size is larger than Prius C, so that should not be a problem, though you may need a center hub ring. If the wheel's offset is close enough to the C's and clears caliper and brake, I think they should fit, but now you are placing slightly wider but overall slightly smaller tire than your OEM. I am not sure if that has any adverse effect on your driving. How much for the Fit wheel and tires is he asking?
    #9 Salamander_King, Oct 11, 2019
  10. Salamander_King
    11,024
    8,970
    New England
    Oh, wait. OP said the snow is 185/65/15 mounted on 15x5.5 rims. That tire size (and rim spec) are not Fit's OEM. If that's the size of snow tire to be compared to Prius C OEM tires, then it is both wider and overall bigger. About a half inch in both directions. Again, I have never used off size tires on my cars, so I can't comment on an effect it has on your driving. Maybe @Rob43 can give you better advise.
  11. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Good catch! you are correct, stock size is 175/65R15. I remembered the wrong value.
  12. Mendel Leisk
    41,915
    Either way it's a change. :)
  13. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Welcome to PriusChat !
    Good for you and congrats !
    What Exact snow tire (brand and model) did you buy ?
    Rob43
  14. unsunder
    unsunder New Member
    Colorado
    Hankook Winter I*cept
    Rob43 likes this.
  15. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Great choice, I bought 4 Hankook Winter iCept iZ2 W616 a few weeks ago based on some incredibly great snow tire test results that were done in Norway during the 2018 season.
    Rob43
  16. Ben Reader
    Ben Reader New Member
    Tampa, FL
    2015 Nissan LEAF
    Same here, fellas. I also bought my own Hankook winter tires. I have to admit, I was just buying for my car's main tires, but after experiencing the smooth ride, I might visit 4WheelOnline again and go for spares.
  17. Tekken
    Tekken Member
    259
    77
    Los Angeles, California
    let me Hijack this post for a suggest
    Since this Prius C with stock tire 175/65/15, but I found a deal set of 4 Kumho new tires 185/65/15. I know it isn't recommend and MPG may reduce. Can 185/65/15 fit this Prius C for just daily drive? Will it little too large and hit the side when make turn?
  18. Dominic Fong
    Dominic Fong Junior Member
    Portland Oregon
    Installed a set of Nokian WRG3(185/65R15) in 2017 and 40000km ago without any problems whatsoever on my 2014 Prius C that came with 175/65R15 as oem tires. It rides as smooth as a Camry without any negative handling or acceleration issues. The wider-than-stock size also assure the rims are free from curb scratches.
