Self parking video
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Oct 17, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Must admit I've never used this feature. Still like backing in myself.
  2. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Intelligent Parking Assist has come a long way since it’s original iteration in my 2008 Prius Tspirit (UK).
    I can only see a Prius Prime as my next Prius. Alas, they don’t sell the version with the 11 inch screen here .
    I wonder why?
    iPad ? Pro
    Tideland Prius likes this.
  3. Tideland Prius
    16,602
    The next gen Yaris has the next generation IPA after the Prime. It doesn’t require driver input on the pedals - just shifting between D and R. (Prime requires pedal input but the system rock the car back and forth in a parallel parking by requesting the driver to switch between D and R)
    Mendel Leisk and Data Daedalus like this.
  4. mister2cool
    mister2cool Member
    98
    51
    New Jersey
    2020 Prius Prime
    I have tried it twice so far just for testing.. those were the scariest and crappest parking job I have ever seen. First time it nearly took out a Tesla parked next to me (my fault for going too fast).. 2nd time it was way off center.
  5. bisco
    52,286
    i don't understand why it isn't perfectly centered with good paint lines like that. i can do a better job just looking in the rear camera
    Data Daedalus likes this.
  6. mister2cool
    mister2cool Member
    98
    51
    New Jersey
    2020 Prius Prime
    You mean the paint lines in the rear view camera is not centered? I sure hope that is the case, because every time I park using only the camera, I end up way to the right...
    Data Daedalus and Tha_Ape like this.
  7. bisco
    52,286
    the lines on the sides of the parking spot
  8. bevhoward
    bevhoward Member
    64
    32
    Austin, Texas
    2020 Prius Prime
    FWIW, apparently only available on the top trim package (LE?) I have the 2020 XLE and it's not included.
    Beverly Howard
  9. Tideland Prius
    16,602
    Limited.
    LE is the base model.
