tie rod
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Oct 18, 2019.
  1. ronlewis
    ronlewis Active Member
    982
    196
    texas
    2001 Prius
    Installing a new passenger-side half axle. The one I bought online doesn't quite look like the one that came off on the transaxle end. The old one had a lip that I don't see on the new one, and the boot looks different. Anyway, without that lip to judge by, I'm not sure I have it fully seated. If it wasn't, would the other end match up with the strut bolts? Thinking that since it all went back together, it must have fully seated.
    I'm also assuming the new axle comes with grease inside the boots for the CV joint.
    On the out side, the hub one slid on and off the new axle easily unlike the problems I had getting the old one back on (never did). May just be that I greased it up this time. However, same question - do I have it all the way in? I still see the edge of the gear teeth outside the hub on the inside. I don't have the axle nut cranked down yet, so maybe that pulls it in closer. Also, don't see how it could be not fully seated on the transaxle and still be short at the hub.
    The problem I know I have (the above may not be problems), is that the tie rod ball joint spins as I try to tighten the nut down. What am I doing wrong there?
    My ability to make a hard job out of an easy one is impressive.
  2. ChapmanF
    18,056
    See if you can fit a Torx bit into the end of the tie rod stud while tightening the nut.
    Brian in Tucson likes this.
  3. ronlewis
    982
    196
    texas
    2001 Prius
    aah, ok. thx.
  4. ronlewis
    982
    196
    texas
    2001 Prius
    Nope, it doesn't have a torx plug, just a smooth end. I'm thinking the two arms need to be pressed together - the opposite of when I broke them apart with a tie rod fork taking the hub off - which would keep the ball joint from spinning. Just not sure how to do that without, what I suppose, is a special tool Toyota probably sells for a few hundred dollars.
    I'm thinking most cars aren't built like this. The bolt is usually fixed in place and merely passes through a round ball joint that swivels to provide the needed functionality.
  5. gothstone
    gothstone Junior Member
    36
    KC MO
    2002 Prius
    Tie rod nut problem is common. Hit it hard and fast with an impact. If no luck reuse the old nut which will go on easier, having the nylon pre threaded.
  6. ChapmanF
    18,056
    Huh. I know the stabilizer link studs had Torx cutouts. Maybe not the tie rod studs.
  7. ronlewis
    982
    196
    texas
    2001 Prius
    Yeah, that's all I could think to do as well. Just don't have access to my impact and air compressor - behind a bunch of junk in my garage, but I getting closer to it, lol. So, I've got to drive it somewhere, real slow and real close, lol.
    Another crazy thing...when I was taking the axle out, my first effort was to just pull on it, and dang if it didn't come off in my hand. I thought that was it - didn't look inside at the transaxle - until the new one came in and was longer. Turns out the original just separated at the inside boot(? - a hard plastic shell with three indentions for the CV joint). The other half of the boot and the rest of the shaft with splines was still in the transaxle.
    That boot tore apart, or was already apart. The shaft that came out ended at the CV joint (?) with a stub end. WTH attached that to the shaft/splines that go inside the transaxle? It didn't look like it snapped; the end was smooth and uniformly rounded. I would have thought there was one long shaft, or that the CV joint somehow joined the two together. I couldn't see anything except the boot holding it together, and that sure came apart easy. I couldn't see how the shaft from the splines attached to the shaft ending after the CV joint, and hard to imagine all that torque being held together by a plastic boot.
    The replacement came as one assembly, which I didn't want to take apart to discover how it works. Just wondering it that shaft was actually broken, but can't imagine it would have driven smoothly like that.
  8. gothstone
    36
    KC MO
    2002 Prius
    Wow, your old half shaft was really trashed to come apart that easy!
    On the tie rod, not my fav method, but works in a pinch. Use whatever adapters and extensions you have to get a socket extension chucked in a drill. Set for its highest speed, and pull the trigger.
  9. ronlewis
    982
    196
    texas
    2001 Prius
    That's what I thought. The remaining part didn't want to pry out of the transaxle either, although I couldn't get much leverage with the long pry bar I had since it was only up on jackstands - no room. I tried wrapping a ratchet strap around it and pulling it out that way, no go, then using that strap to put constant pressure while I pried, still nothing. Finally got a short wooden block on the back of that boot from the driver's side and a couple of whacks with the BFHammer popped it right off.
  10. ChapmanF
    18,056
    The joint doesn't need much more than the rubber boot to hold it together. In normal operation, the transmission isn't going anywhere, and neither is the steering knuckle, so it's not like the joint has any opportunity to come apart.
  11. ronlewis
    982
    196
    texas
    2001 Prius
    I guess you're right; I'm no engineer. Just would think there is torque in the axle itself as it tries to propel the vehicle. How is it different from rear wheel drive cars that have solid connections?
  12. ChapmanF
    18,056
    The old-fashioned U-joints in a RWD driveshaft will allow the shaft to handle slight angles as the rear axle bounces up and down, but don't allow it to shorten or lengthen much (and it doesn't really have to). Often it will have kind of a splined slip yoke into the transmission, giving it a little freedom to slip in or out, since the length isn't perfectly constant as the rear axle bumps around.
    But the slip yoke is never going to slip all the way out of the transmission, unless you first disconnect the other driveshaft end, or unbolt and move the whole rear axle backward, or the like. Right? As long as it's the length it is, and the tranny and the rear axle are where they are, it isn't going to come apart.
    It's the same with the FWD axles. They have to accommodate bigger angle changes because of steering, and also bigger length changes (certainly bigger in proportion, 'cause they're stubby little shafts to begin with compared to a RWD driveshaft). So the joint is built so it transmits torque just fine, and turns angles just fine, and also can slip inward and outward some (hence the pleated boot).
    But as long as the transmission is where it is, and the knuckle is where it is, and the shaft is connected to both, its length is stuck within those fairly strict bounds; the innie won't be slipping out of the outie.
