Thule Transporter Combi
Discussion in 'Prius c Accessories and Modifications' started by LnG, Oct 19, 2019.
  1. LnG
    LnG Junior Member
    73
    Northern Hemisphere
    2016 Prius c
    I've been looking for a solution to my mod / space issues. This box is the closest thing I have found, anyone have one of these? I don't car for having to have a license plate and lights adapter but it leaves the roof space open (solar install).
    Thule Transporter Combi | Thule | USA
    I
    f there is a better one out there I'd like to know - I think I'm getting one of these!
    Hitch Cargo Box - Standard | StowAway
    #1 LnG, Oct 19, 2019
  2. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    Looks like something that will either fall off while going down the road or tapped by someone while your sitting at a light.
    Why not just get a roof rack instead of getting a hitch installed, buying a box etc... A roof rack would save you a ton of cash.
  3. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    +1 on roof rack.
    you will still have space on your hood and other places for solar
    and with the box, you will be limited to the tongue weight of the hitch
  4. LnG
    LnG Junior Member
    73
    Northern Hemisphere
    2016 Prius c
    The cargo carrier doesn't look :cautious: that :cautious: bad.:LOL: If someone is following me that close to hit me, that person is an idiot. The roof rails and rack is cheaper but only by a couple hundred.
  5. LnG
    LnG Junior Member
    73
    Northern Hemisphere
    2016 Prius c
    The rhino rack roof bars and master fit roof box 440L on a grey metallic '16 Prius C?
  6. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    That looks like about an 18" lever arm on the hitch and 30" lever arm on the hitch-bumper mounting pts. Carrier box CG puts that closer to 40". A 200lb load (plus 55lbs for the box itself) would translate to approximately 840 ft-lbs of torque on the bumper mounts. You could provide some relief with a bicycle rack strap (similar to what's used with the Uhaul 1 1/4 hitch). Otherwise, it seems that you could easily exceed the bumper limits. You would have to limit the contents of the carrier to light weight, bulky items.
    #6 ice9, Oct 20, 2019
  7. Leadfoot J. McCoalroller
    8,067
    7,548
    Pennsylvania
    2018 Prius c
    Why not get an SUV?
    More space to haul stuff, more roof space, and probably gets better highway MPG than a Prius covered with external luggage.
    (I know, I know, luggage is cheaper than switching cars.)
    dig4dirt likes this.
  8. Jeff Hicks
    Jeff Hicks Junior Member
    37
    24
    Huntsville, AL
    2020 Prius Prime
    I have one that works great for my Lexus LX. I got it on Craigslist for 200.00!
    I have never used the ROLA 59109, but it has the swing away feature and you can take the box off and just have the tray if needed. 2" hitch and I don't know how much weight it would "create" on the receiver when it is swung out when loaded.
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    LnG likes this.
