Auto Leveling headlights are cool...
Discussion in 'Gen 2 Prius Main Forum' started by Maytrix, Sep 13, 2006.
  1. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    I never really knew how much of a difference the auto-leveling headlights made or how much they actually could adjust until mine stopped working. Apparently, the sensor for mine went, which in turn caused them to go to their lowest setting. This was apparent to me because at night, the headlights only pointed about 20' in front of my car.
    I actually questioned myself quite a bit on this and wasn't really sure, but when I was in for regular service, I had them check it. After I got it back all fixed up, It was so apparent how big a difference it is.
    The odd thing though is I can tell how much of a difference the feature really makes when driving. Can anyone tell? When is it the most helpful?
  2. Kev1000000
    Kev1000000 New Member
    271
    Livonia, MI
    My sensor broke as well. And my car was JUST out of warranty =(
  3. KTPhil
    KTPhil Active Member
    1,379
    Warrantee or no, it shouldn't cost you; there is a TSB out on this:
    US TSB EL004-06
    April 28, 2006. Automatic Headlight Leveling System Warning Light "ON" or Flashing. 2004-2005 Prius w/HID headlights. replace rear vehicle height control sensor with improved one.
  4. galaxee
    galaxee mostly benevolent
    9,810
    470
    MD
    tsb: covered only under warranty.
    recall: covered regardless of warranty.
  5. onerpm
    onerpm New Member
    477
    MN
    mine went too (under warranty). no idiot light, though, just superlow aim. first dealer I took it to said they were fine... they determined that by comparing the aim with that of another Prius that was in for service (!!!). Second dealer had brains, replaced the sensor, problem solved. what a difference, as you pointed out, Maytrix.
    rpm
  6. Drifter
    Drifter Member
    102
    chicago area
    I had my sensor replaced under warranty a couple months back. The light was on and off, but mostly on, for three weeks. Of course it was off both when I brought the car in to report the problem and when I brought it back after they ordered the part. But they replaced it anyway and no problems since. I never actually noticed the headlights doing anything strange but I didn't want them to start acting up at a bad time.
  7. deh2k
    deh2k New Member
    241
    New Hampshire
    Mine went out too. The lights were aimed really low, probably since the car was new. I thought they were just aimed that way on purpose. Duh. When it was about 18 months old the warning light went on, took it in, and was told the sensor was broken. Had it replaced and the difference was huge. You could say it was like night and day! It was still under warranty so I didn't have to pay the $300+ bill.
    I encourage anyone with HID lights that seem aimed low to have the sensor checked out before the warranty expires.
