Genuine OEM Spark Plugs?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by darkgiant, Oct 26, 2019.
  1. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I am looking to do a spark plug change on my 2013 Prius and 2008 Prius (I know, this is gen 3 forum... my bad!), but unfortunately, after coming across multiple ones on Amazon, I am seeing some reviews mention of fake spark plugs ripping off the original Denso SC16HR11 (which I believe is the OEM ones for both the 2013 and 2008 Prius). Does anyone know which seller or where to find genuine OEM spark plugs (preferably on Amazon), rather than the stealership (who quoted me $84 for 4 freaking spark plugs!)?
    For reference, here are some of the Amazon spark plugs I found that contain reviews that point out possible "knockoffs" this and this.
    mjoo likes this.
    52,277
    try some of the online toyota dealers for pricing. the aftermarket has been flooded with chinese clones. even the suppliers don't know they're fake.
  3. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    You can order Denso through autozone if you wanted to go local. Most likely a special order though.
    -Spiral
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    As @bisco also suggests, if you’re concerned about counterfeit parts, the safest course would be to buy online or in person from an authorized Toyota dealer, so the supply chain would run only from Denso, to the Toyota parts distribution center, to the dealer, to you.
    I couldn’t recommend buying from Amazon or a third-party seller whose inventory, even if genuine, might have been commingled in the fulfillment center with counterfeits from another source. Parts sold on Amazon.com by a Toyota dealer and shipped directly from the dealer to you, however, are more likely to be genuine.
    The current Toyota (Denso) part numbers are 90080-91184 (SK16R11) for the 2008 and 90919-01275 (SC16HR11) for the 2013.
    Robert Holt and Rebound like this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  6. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I’ve ordered from Conicelli before and they’re great to deal with.
    Spark plugs and high speed camera memory cards are two things I will never buy from Amazon or eBay. Far too much risk of counterfeit goods.
  7. bisco
    52,277
    40 bucks, well worth it
  8. Mendel Leisk
    41,822
    Phone around, try several dealerships (they'll likely all be close though) and a few automotive retailers. The latter will probably have better prices, by maybe 30%.
    Myself, I buy plugs from a small local automotive place. They're very competent, have good prices, and must have good sources, never had a problem.
    Still, being in Canada, I wouldn't blink an eye at spending over $100 for four long-life plugs. Things are often more expensive up here, and of course the Canadian $'s maybe 75% versus the US. Think too: this is a once-every 12 years or 120K miles event?
  9. Peter123
    Peter123 Active Member
    132
    128
    My brother had a bad batch of Denso plugs. I replaced them with NGK 4912 plugs from Rock Auto and they worked just fine.
    On an alternate note, NGK are also selling Ruthenium plugs as an upgrade from Iridium plugs.
    tankyuong likes this.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    The Denso 3324 (SK16R11) which is OEM for the Gen 2 is available on Rock Auto for less than $6 each.
  11. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I have called around the local dealershps and unfortunately, the price doesn't vary... however it looks like RockAuto seems to be a reliable source? It is definitely a lot cheaper (for instance, ~$29 for the SK16R11 Denso Spark Plugs). I guess RockAuto is my new source for parts?
  12. Eddie25
    Eddie25 Active Member
    501
    212
    MI
    Just went through the exact same thing including the NGK's from Rock Auto. Now I'm even questioning that decision. How trusted is Rock Auto? I have no idea how they work, as far as I know it could be an amazon type situation. I'd personally stick to the auto-parts store or dealer on this one.
    Rebound likes this.
  13. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Oh okay... well it looks like AutoZone does carry the Denso 3324 (SK16R11) for $8.50 a pop, might as well just get it there I suppose?
  14. Peter123
    132
    128
    I have been buying parts from Rock Auto for years and have never had a problem.
  15. Eddie25
    501
    212
    MI
    So have I. I'm not knocking Rock Auto I'm just saying I don't know how they work. Do they get from the source or do they go with the cheapest option? I'm honestly curious. Spark plugs are inexpensive, important, and apparently they are commonly counterfeit. You also won't know they are bad for 20,000 miles or so. I'm just saying in the future I'll go to the store for plugs just for the piece of mind.
    Dragonfly1993 likes this.
  16. bisco
    52,277
    it is really a supply chain issue. how do they oversee the process, to make sure unwanted black market parts don't infiltrate at some point.
    Tande likes this.
  17. Dragonfly1993
    Dragonfly1993 Junior Member
    San Antonio
    #17 Dragonfly1993, Nov 20, 2019
  18. anonymous
    anonymous Member
    177
    99
    US
    Rock Auto sells spark plugs? I couldn't find spark plugs anywhere on their site.
    Edit: nvm found them by checking "Part Catalog" for the specific vehicle. Damn they're cheaper than what we got from autozone; if only I found them!
  19. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    Just look under "ignition" after you select your car model.
