Fan wont blow
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Grahf, Oct 27, 2019.
  1. Grahf
    Grahf New Member
    East Coast
    2005 Prius, 181K miles. No heat or AC for a couple weeks so I figured the fan motor was bad. Just replaced the fan motor (if that's what it's called) under the glove box. Haven't put everything back together but I plugged in the new fan motor, turned on the car, turn on AC....no air....turned on defrost....no air. There's just a low whining sound that comes from under the hood when I turn on the AC of defrost. Any ideas on what could be causing the fan not to blow?
  2. Grahf
    Grahf New Member
    East Coast
    Replaced the motor resistor/controller and it works now :)
    chrisinator13 and bisco like this.
  3. Aegean
    Aegean Active Member
    461
    203
    Alexandria VA
    Maybe check with a voltmeter at the fan connector. Do you get voltage? I assume you checked the fuse already.
  4. bisco
    51,787
    well done!(y)
